34454
34454
    DESCO
    ESDSHPTRVLR10X12CLR/RD10PK
34454 数据手册
10" (254mm) SPECIFICATIONS • OPENING • • 11" (280mm) • *PAPER INSERT • 12" (305mm) 8 1/2" (216mm) • • • • • Made in the United States of America Choice of 4 header colors to help identify your group, department and work instructions; keep track of everyone at your facility; or just assist in organizing your meetings or events The ESD Shop Traveler is made using 0.012” (0.3 mm) thick ESD vinyl on front and back and 0.010” (0.25 mm) clear rigid vinyl as liner Includes inner anti-print, non-ESD vinyl liner which will prevent ink transfer from your document to the document holder Ideal for use by electronic manufacturers who work with ESD sensitive components Marked with ESD Protective symbol; ideal for use by electronic manufacturers who work with ESD sensitive components Dissipative vinyl 1 x 104 to < 1 x 1011 ohms, per ANSI/ESD STM11.11. Meets ANSI/ESD S20.20 and ANSI/ESD S541 Designed to hold "A" size 8 1/2" (216mm) x 11" (280mm) documents Pre-punched metal grommet hang hole Zipper is made from non-ESD vinyl Made in the United States of America Item Description 34454 ESD Shop Traveler, Zip, Clear, 10" x 12" (254 x 305mm), Red Header, 10 Pack 34455 ESD Shop Traveler, Zip, Clear, 10" x 12" (254 x 305mm), Blue Header, 10 Pack 34456 ESD Shop Traveler, Zip, Clear, 10" x 12" (254 x 305mm), Green Header, 10 Pack 34457 ESD Shop Traveler, Zip, Clear, 10" x 12" (254 x 305mm), Yellow Header, 10 Pack *Watermark not on actual product. "It should be understood that any object, item, material or person could be a source of static electricity in the work environment. Removal of unnecessary nonconductors, replacing nonconductive materials with dissipative or conductive materials and grounding all conductors are the principle methods of controlling static electricity in the workplace, regardless of the activity.” (ESD Handbook ESD TR20.20 section 2.4 Sources of Static Electricity)” ± 1/16" tolerances on dimensions unless specified Specifications and procedures subject to change without notice. ESD SHOP TRAVELER, ZIP, CLEAR, RED/BLUE/GREEN/YELLOW HEADER, 8 1/2" (216MM) x 11" (280MM) INSERT SIZE 3651 WALNUT AVENUE CHINO, CA 91710 PHONE: (909) 627-2453 WEBSITE: MENDATools.com © 2021 DESCO INDUSTRIES INC. Employee Owned DRAWING NUMBER 34454 DATE April 2021 Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Menda: 34455 34456 34457 34454
34454 价格&库存
很抱歉,暂时无法提供与“34454”相匹配的价格&库存,您可以联系我们找货
