10"
(254mm)
SPECIFICATIONS
OPENING
11"
(280mm)
*PAPER INSERT
12"
(305mm)
8 1/2"
(216mm)
Made in the
United States of America
Choice of 4 header colors to help identify your group, department and work
instructions; keep track of everyone at your facility; or just assist in organizing
your meetings or events
The ESD Shop Traveler is made using 0.012” (0.3 mm) thick ESD vinyl on front
and back and 0.010” (0.25 mm) clear rigid vinyl as liner
Includes inner anti-print, non-ESD vinyl liner which will prevent ink transfer from
your document to the document holder
Ideal for use by electronic manufacturers who work with ESD sensitive
components
Marked with ESD Protective symbol; ideal for use by electronic manufacturers
who work with ESD sensitive components
Dissipative vinyl 1 x 104 to < 1 x 1011 ohms, per ANSI/ESD STM11.11. Meets
ANSI/ESD S20.20 and ANSI/ESD S541
Designed to hold "A" size 8 1/2" (216mm) x 11" (280mm) documents
Pre-punched metal grommet hang hole
Zipper is made from non-ESD vinyl
Made in the United States of America
Item Description
34454 ESD Shop Traveler, Zip, Clear, 10" x 12" (254 x 305mm), Red Header, 10 Pack
34455 ESD Shop Traveler, Zip, Clear, 10" x 12" (254 x 305mm), Blue Header, 10 Pack
34456 ESD Shop Traveler, Zip, Clear, 10" x 12" (254 x 305mm), Green Header, 10 Pack
34457 ESD Shop Traveler, Zip, Clear, 10" x 12" (254 x 305mm), Yellow Header, 10 Pack
*Watermark not on actual product.
"It should be understood that any object, item, material or person could be a source
of static electricity in the work environment. Removal of unnecessary nonconductors,
replacing nonconductive materials with dissipative or conductive materials and grounding
all conductors are the principle methods of controlling static electricity in the workplace,
regardless of the activity.” (ESD Handbook ESD TR20.20 section 2.4 Sources of Static
Electricity)”
± 1/16" tolerances on dimensions unless specified
Specifications and procedures subject to change without notice.
ESD SHOP TRAVELER, ZIP, CLEAR, RED/BLUE/GREEN/YELLOW
HEADER, 8 1/2" (216MM) x 11" (280MM) INSERT SIZE
3651 WALNUT AVENUE CHINO, CA 91710
PHONE: (909) 627-2453
WEBSITE: MENDATools.com
© 2021 DESCO INDUSTRIES INC.
Employee Owned
DRAWING
NUMBER
34454
DATE
April
2021
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
Menda:
34455 34456 34457 34454
很抱歉,暂时无法提供与“34455”相匹配的价格&库存,您可以联系我们找货
