Made in the
United States of America
OPENING
Description:
This product is designed for use in ESD protected areas where there are ESD susceptible
devices. This product is constructed out of 6 mil, clear, permanently dissipative
polyethylene film. Shop travelers are designed to provide static control packaging for
holding engineering drawings or other large documents.
Amine-free.
N-Octanoic acid free.
Humidity independent.
Does not promote corrosion.
Has no measurable outgassing.
12"
Electrical Properties:
Static Decay:
< 2.0 sec.
Surface Resistance:
10E4 to < 10E11 ohms
per FTMS 101C, Method 4046
per ANSI/ESD STM11.11
Specifications:
Polycarbonate haze:
Corrosivity:
Melt Index:
Density:
Dart impact:
Coefficient of friction:
1% secant modulus:
Stiffness:
72 hr contact
per FTMS 101C, Method 3005
per ASTM D-1238
per ASTM D-1505
per ASTM D-1709
per ASTM D-1894
per ASTM D-882
per ASTM D-882
Negligible
Neglibible
.050 gm/10 min.
0.923 gm/cc
230 gms
0.50
MD 24,000 psi
MD 25,000 psi
10"
“It should be understood that any object, item, material or
person could be a source of static electricity in the work
environment. Removal of unnecessary nonconductors,
replacing nonconductive materials with dissipative or
conductive materials and grounding all conductors are
the principle methods of controlling static electricity in the
workplace, regardless of the activity.” [ESD Handbook ESD
TR20.20-2008 section 2.4 Sources of Static Electricity]
Inside Dimension Tolerances are -0/+1/4" unless specified
Specifications and procedures subject to change without notice.
A. Shop Travelers will hold up to an 8-1/2” x 11” sheet size.
Wording across bottom area:
Statfree®
Shop Traveler
47121 / 07454
Made in America
DescoIndustries.com
Statfree® Shop Traveler, 6 Mil
PROTEKTIVE PAK
13520 MONTE VISTA AVENUE, CHINO, CA 91710
PHONE (909) 627-2578, FAX (909) 363-7331
ProtektivePak.com
© 2012 DESCO INDUSTRIES INC.
Employee Owned
DRAWING NUMBER
47121
DATE:
February
2012
很抱歉,暂时无法提供与“47121”相匹配的价格&库存,您可以联系我们找货
