TECHNICAL BULLETIN TB-5536
Ground Gard 4.5
Operation, Installation, and Maintenance
Made in the
United States of America
Continuous Monitors eliminate the need for users to
test wrist straps and log the results; by their function,
these monitors satisfy the ISO 9000 and ANSI/ESD
S20.20 Paragraph 6.2.2.2 test logging requirements.
Per ESD-S1.1 paragraph 6.1.3 Frequency of Functional
Testing “Daily (Wrist Strap) testing may be omitted if
constant monitoring is used.”
94390
94392
Figure 1. SPI Ground Gard 4.5
Description
The Ground Gard 4.5 is a wrist strap and ground
monitoring device for the electronics work station. It is
designed to constantly monitor two single wire wrist
straps using a Remote Operator Module for each user.
This unit provides continuous monitoring of:
• Two users wearing a wrist strap
• Ground
For a SPI Continuous Monitor that also monitors the
ESD worksurface see SPI model Ground Gard 5.
Leading companies use continuous monitors as a cost
effective component in satisfying the paragraph 6.1.3
Complicance Verification Plan requirements of ANSI/
ESD S20.20. The SPI Ground Gard 4.5 Continuous
Monitor provides continuous monitoring of two operators
and also functions to ensure connection to ground. If the
monitor, using capacitance technology, detects improper
grounding of the operator, the monitor will issue an
audible alarm alongwith an illuminated red LED to notify
the user of a problem.
Many customers are eliminating periodic testing and are
utilizing continuous monitoring to better ensure that their
products were manufactured in an ESD controlled
environment. Continuous monitoring is superior to
periodic testing. “While effective at the time of testing,
wrist strap checker use is periodic. The failure of a wrist
strap between checks may expose products to damage
from electrostatic charge. If the wrist strap system is
checked at the beginning of a shift and subsequently
fails, then an entire shift’s work could be suspect.” (ESD
TR 12-1 Section 1.0 Survey of Constant Monitors for
Wrist Straps)
“Because wrist straps have a finite life, it is important to
develop a test frequency that will guarantee integrity of
the system. Typical test programs recommend that wrist
straps that are used daily should be tested daily.
However, if the products that are being produced are
of such value that knowledge of a continuous, reliable
ground is needed, and then continuous monitoring
should be considered or even required.” (ESD Handbook
TR 20.20 section 5.3.2.4.4)
The Ground Gard 4.5 is available in two models. The
item numbers are listed below:
Item
Description
94392 Ground Gard 4.5 with Buzzer, 120V
94390 Ground Gard 4.5 with Buzzer, Building Ground, 120V
*Contact manufacturer for quote on 220V models
The Ground Gard 4.5 will alarm if preset values are
exceeded for capacitance, high resistance and ground
loss conditions. The grounding system is redundant
and will still provide limited grounding even if the utility
ground is lost and the system is in an alarm state.
Capacitance Type Continuous Monitors
“This type of monitor is used with a single wire (single
conductor) wrist strap. Monitors in this category operate
by “sensing” body capacitance. For capacitance
monitors, an AC voltage is applied to the wrist strap
through the single conductor ground cord. Due to
capacitive coupling of the person to ground based on the
surroundings, the monitor will indicate either good or bad
depending on the manual adjustment or preset
tolerance. SInce a capacitor or capacitive network
responds like a resistor to an AC current, the single
conductor wrist strap monitor only provides an estimate
of the wrist strap wearer’s apparent resistance.” (ESD
Handbook TR 20.20 section 5.3.9.2 Types of Continuous
Monitors)
ESD
Systems.com
• 432 Northboro
Road
Central •MA
Marlboro,
MA 01752
• (508)
• Website:
ESDSystems.com
ESD
Systems.com
• 432 Northboro
Road Central
• Marlboro,
01752 • (508)
485-7390
• Fax485-7390
(508) 480-0257
• Website:
ESDSystems.com
TB-5536 August 2018 Page 1 of 3
© 2018 DESCO INDUSTRIES INC
Employee Owned
Packaging
Remote Module Description
Installation
Should the wrist strap fail, be worn incorrectly or
removed by the operator, the red indicator will flash,
calling attention to a problem. Should the ground
connection be lost, the red light and alarm will be
activated The monitors are continuous and even
a momentary break will cause alarms. The remote
modules are set at the factory to allow for sensitivity of
the “average” human body model.
1
2
1
1
1
1
1
Ground Gard 4.5 Monitor
94340 Operator Remotes
Operator Remote Cables, 10 ft.
Monitor Ground Cord, 12 ft. (94390 only)
Hook and Loop Fastener Strip
12VDC Power Adapter, North America
Certificate of Calibration
1. GROUND GARD 4.5 Monitor Head:
The Ground Gard 4.5 Monitor Head is designed to
maximize valuable work area and should be mounted at
eye level above the workstation, either on a post or shelf
support. A double-sided adhesive Velcro® attachment is
provided to hold the lightweight head in place.
2. GROUND CONNECTION:
The green wire extending from the monitor head (item
94390) must be attached to equipment ground. This wire
can be connected directly or looped through the
conductive table top or mat to ground. There is no green
wire on item 94392. For this item, the ground connection
is made through the third prong of the 3-wire Power
Adapter.
Caution: The total amount of resistance through all
monitored parts should not exceed 10.0 megohms
total.
3. REMOTE OPERATOR MODULES:
The remote operator modules can be
mounted at the front of the work
surface, usually under the tabletop and
flush with the front edge. Two screws for each unit are
provided for mounting. Connect each remote to the
monitor unit using the telephone cable with RJ11
connectors.
4. POWER UP TEST
After installing the Monitor Head, remote units, and
making the necessary connections without the wrist
straps connected, the unit should POWER UP with the
wrist strap LED’s OFF and the audible alarm SILENT.
If you have no response to power or a red LED, check
AC outlet for proper ground or refer to trouble shooting
section.
PARK SNAP
The audible alarm is designed to alert both operator and
supervisor. The Park Snap feature provides a means
for an operator to disconnect when normally leaving
the work area, without the audible alarm sounding, and
it provides a means of wrist cord storage (visual red
LED will illuminate). You may also disconnect coil cord
by unplugging banana plug from the Remote Operator
Module. Both a 7mm and 4mm Park Snap is provided on
each module.
Inside both remote modules are infrared sensors that
react to the insertion of a wrist strap wire with a banana
plug. When the banana plug is inserted, the base unit is
activated for that remote module. The Monitor Head LED
for the left or right wrist strap will light showing the
condition of that strap. If correct, the LED should be
GREEN.
Calibration Procedure Using 94335
Tester
With coiled wires connected to test unit and each remote,
observe the following: both lights should illuminate green
on the head module, with no buttons depressed on the
tester. Pressing buttons one or four should cause the left
or right wrist strap to go red simulating a high resistance
condition on the wrist strap. This shows that the Remote
Operator Module is properly calibrated.
If the above conditions are not met, complete the
following adjustment:
With buttons one and four not depressed, the LED
display on the head module should be in a green
condition. If not, find the adjusting port on the remote.
Inside there is an adjusting trim pot. Turn the trim pot
slightly until the head module LED turns green.
Step One: Turn the pot until the green LED triggers red,
then ease back until LED triggers green.
Step Two: Press the corresponding button on the test
unit and the LED will go red on the head module. This
shows the Ground Gard remote is in a proper calibration.
Note: If the unit does not go red, go back to step one
and repeat procedure.
Installation Adjustments
Should your system alarm without obvious cause, first
troubleshoot and verify all connections. If all the
connections are correct, the base unit should be
adjusted to compensate for a different HBM (human
body model). We preset the units at the factory at 100pF
and your operator might be out of the tolerance range
caused either by body chemistry, bulk capacitance or
impedance differences.
Follow these steps to adjust and personalize the base
unit:
ESD
Systems.com
• 432 Northboro
Road
Central •MA
Marlboro,
MA 01752
• (508)
• Website:
ESDSystems.com
ESD
Systems.com
• 432 Northboro
Road Central
• Marlboro,
01752 • (508)
485-7390
• Fax485-7390
(508) 480-0257
• Website:
ESDSystems.com
TB-5536 Page 2 of 3
Employee Owned
Locate the small hole in the face of the remote module
(factory adjustment label my cover hole). Inside this hole
is a trim pot device that is adjustable by using a small
flat-head screwdriver.
With the system set up and operating, and the operator’s
wrist strap connected to the remote module:
Limited Warranty, Warranty Exclusions, Limit
of Liability and RMA Request Instructions
See the ESD Systems Warranty ESDSystems.com/Limited-Warranty.aspx
1. Turn the pot until the green light activates. Disconnect
the wrist wire from the band. The unit should alarm and
activate the red light. If not, turn the trim pot until the
red light activates. Reconnect the wire to the wrist band
and the alarm should cease and the green light should
activate.
2. Turn the pot until the green light begins. Disconnect
the wrist wire from the band. The unit will alarm and
activate the red light. If not, turn the trim pot until the red
light activates. Reconnect the wire to the wristband and
the alarm will cease, the green light will activate.
Safety Issues
With regards to the safety issue, it is hard to conceive of
asafer situation than exists with the Ground Gard 4.5 as
designed.
1. The Ground Gard 4.5 has a built-in safety resistance
of no less than 500k ohms at each remote unit.
2. The transformer is wound on a split bobbin with 1500
volt insulation to assure no possible line leakage.
3. The circuits are double insulated by virtue of the
insulated plastic boxes.
4. 500k ohms internal to the Ground Gard and one
megohm in the wrist strap isolate the operator.
This may be varified by using a miltimeter set on ohms.
Connect the telephone type wire to the head monitor and
to the remote unit. Place one end of the probe into the
banana receptacle at the remote, and the other to the
collar (power supply jack) located at the head monitor.
ESD
Systems.com
• 432 Northboro
Road
Central •MA
Marlboro,
MA 01752
• (508)
• Website:
ESDSystems.com
ESD
Systems.com
• 432 Northboro
Road Central
• Marlboro,
01752 • (508)
485-7390
• Fax485-7390
(508) 480-0257
• Website:
ESDSystems.com
TB-5536 Page 3 of 3
Employee Owned
