Opening
Description:
Desco’s heavy weight (6 mil) shop traveler is made from a static dissipative coextruded
polyolefin material. The triboelectric charge generation of the material is negligible (tested per
EIA-541) to make them safe for use around ESD susceptible items. They are designed for
top loading a standard 11" x 17" (B Size) sheet of paper.
Electrical Properties:
Static Decay:
Surface Resistance:
< 2.0 sec.
1 x 10^4 < 1 x 10^11 ohms
per FTMS 101C, Method 4046
per ANSI/ESD STM11.11
17.25"
Specifications:
Statfree®
B Size
Document Holder
07456 / 47123
Made in America
DescoIndustries.com
11.25"
RoHS and REACH Compliance Statement
None of the RoHS restricted materials or REACH substances of very
high concern are intentionally added in manufacturing this product. Ref:
Directive 2002/95/EC Article 4.1. and Regulation (EC) No. 1907/2006.
See Desco Industries Inc. Limited Warranty at Desco.com.
Per ANSI/ESD S541 section 7.2.2 Resistance of Dissipative Materials “A
static dissipative material shall have a surface resistance of greater than
or equal to 1.0 x 10^4 ohms but less than 1.0 x 10^11 ohms. Packaging
materials that are in intimate contact with devices should be dissipative.”
“It should be understood that any object, item, material or person could
be a source of static electricity in the work environment. Removal of
unnecessary nonconductors, replacing nonconductive materials with
dissipative or conductive materials and grounding all conductors are
the principle methods of controlling static electricity in the workplace,
regardless of the activity.” [ESD Handbook ESD TR20.20-2008 section 2.4
Sources of Static Electricity]
Polycarbonate haze:
Negligible
Corrosivity:
Neglibible
Melt Index:
.050 gm/10 min.
Density:
0.923 gm/cc
Dart impact:
230 gms
Coefficient of friction:
0.50
1% secant modulus:
MD 24,000 psi
Stiffness:
MD 25,000 psi
N-Octanoic Acid Free
Has No Measurable Outgassing
B size document holder will hold up to an 11" x 17" sheet size.
Wording across bottom area:
Statfree®
B Size
Document Holder
07456 / 47123
Made in America
DescoIndustries.com
Inside Dimension Tolerances are -0/+1/4" unless specified
STATFREE® DOCUMENT HOLDER, 6 MIL
DESCO EAST: ONE COLGATE WAY, CANTON, MA 02021-1407
PHONE (781) 821-8370
Employee Owned
Made in the
United States of America
Specifications and procedures subject to change without notice.
DESCO WEST: 3651 WALNUT AVE., CHINO, CA 91710 WEB SITE: Desco.com
PHONE (909) 627-8178
© 2012 DESCO INDUSTRIES INC.
72 hr contact
per FTMS 101C, Method 3005
per ASTM D-1238
per ASTM D-1505
per ASTM D-1709
per ASTM D-1894
per ASTM D-882
per ASTM D-882
DRAWING NUMBER
07456
DATE:
April
2012
很抱歉,暂时无法提供与“07456”相匹配的价格&库存,您可以联系我们找货
