68202
68202
    DESCO
    CART COVER 24" X 48" X 62"
68202 数据手册
W Made in the United States of America Description Desco’s clear Dissipative Cart Covers are made from a dissipative (1 x 109 to < 1 x 1011 ohms per ANSI/ESD STM11.11) and low charging 0.012 inch polyvinylchloride (PVC) material. They are designed to be used with ESD susceptible items and allow contents of the carts to be identified without opening the cover. The covers include zippered front flaps that may be left open for access to the cart when the flap is opened. The flap can be locked (lock not included) closed to prevent tampering with cart contents when not in use. A dissipative document pocket is located on the outside of the cart to store documents. Electrical Properties H 1 x 109 to < 1 x 1011 ohms per ANSI/ESD STM11.11 Surface Resistance Physical Properties Color Emboss Pattern Clear* Non-Embossed Gauge Tensile Elongation Tear 0.012" ± 0.002" (~1/80", 12 mils) 1000lb/in2 minimum 150% minimum 125 lb/in minimum ASTM D412, Die C ASTM D412, Die C ASTM D624, Die C Chemical Resistance D Resistant to degradation by inorganic acids, organic acids, reducing agents, detergent solutions, alcohols, aliphatic hydrocarbons, mineral oil, amines, and aldehydes. Item Description (DxWxH) 68200 Cart Cover, 23" x 32" x 41" 68201 Cart Cover, 24" x 36" x 62" 68202 Cart Cover, 24" x 48" x 62" *Color and texture may vary between lots and mills. Original product color may change over time. Unless otherwise noted, tolerance ±10% Specifications and procedures subject to change without notice. Document Holder Pocket Zipper Cart Cover, Dissipative DESCO WEST: 3651 WALNUT AVE., CHINO, CA 91710 WEB SITE: Desco.com PHONE (909) 627-8178 FAX (909) 627-7449 DESCO EAST: ONE COLGATE WAY, CANTON, MA 02021-1407 PHONE (781) 821-8370 FAX (781) 575-0172 © 2014 DESCO INDUSTRIES INC. Employee Owned DRAWING NUMBER 68200 DATE: August 2014
68202 价格&库存
很抱歉,暂时无法提供与“68202”相匹配的价格&库存,您可以联系我们找货
  • 1+5461.347331+704.55880
