47123
47123
    DESCO
    DCMNTHLDR11-1/4X17-1/225/PK
47123 数据手册
Made in the United States of America Opening Description: This product is designed for use in ESD controlled areas where there are ESD susceptible devices. This product is constructed out of 6 mil, clear, permanently dissipative polyethylene film. Document holders are designed to provide static control packaging for holding engineering drawings or other large documents. Amine-free. N-Octanoic acid free. Humidity independent. Does not promote corrosion. Has no measurable outgassing. 17 - 1/4" 11 - 1/4" “It should be understood that any object, item, material or person could be a source of static electricity in the work environment. Removal of unnecessary nonconductors, replacing nonconductive materials with dissipative or conductive materials and grounding all conductors are the principle methods of controlling static electricity in the workplace, regardless of the activity.” [ESD Handbook ESD TR20.20-2008 section 2.4 Sources of Static Electricity] Electrical Properties: Static Decay: < 2.0 sec. Surface Resistance: 10E4 to < 10E11 ohms per FTMS 101C, Method 4046 per ANSI/ESD STM11.11 Specifications: Polycarbonate haze: Corrosivity: Melt Index: Density: Dart impact: Coefficient of friction: 1% secant modulus: Stiffness: 72 hr contact per FTMS 101C, Method 3005 per ASTM D-1238 per ASTM D-1505 per ASTM D-1709 per ASTM D-1894 per ASTM D-882 per ASTM D-882 Negligible Neglibible .050 gm/10 min. 0.923 gm/cc 230 gms 0.50 MD 24,000 psi MD 25,000 psi A. B size document holder will hold up to an 11" x 17" sheet size. Wording across bottom area: Statfree® Inside Dimension Tolerances are -0/+1/4" unless specified Specifications and procedures subject to change without notice. B Size Document Holder 47123 / 07456 Made in America DescoIndustries.com Statfree® Document Holder, 6 Mil PROTEKTIVE PAK 13520 MONTE VISTA AVENUE, CHINO, CA 91710 PHONE (909) 627-2578, FAX (909) 363-7331 ProtektivePak.com © 2012 DESCO INDUSTRIES INC. Employee Owned DRAWING NUMBER 47123 DATE: February 2012
47123 价格&库存
很抱歉,暂时无法提供与“47123”相匹配的价格&库存,您可以联系我们找货
