770036
770036
    SCS
    PROGRAMMERSMPDEVICEID
770036 数据手册
USER GUIDE TB-9058 SMP Device ID Programmer Installation and Operation Instructions Installation Driver Installation 1. Use the included USB cable to connect the SMP Device ID Programmer to your PC. 2. Windows will generally find and install its driver automatically. Use the included Driver Installation CD if this does not happen. 3. Take note of the COM port that Windows assigns to the SMP Device ID Programmer. SCS 770036 SMP Device ID Programmer Description The SCS SMP Device ID Programmer is used to program the Modbus address for the SCS EM Aware Monitor, WS Aware Monitor and Ground Master Monitor. Programming of the Modbus address allows the SCS SMP Software to locate and poll each monitor. The SMP Device ID Programmer is compatible with the following items: Item Description CTC034-030-5-WW EM Aware Monitor, Event Only, Modbus Output SMP ID Programmer Software 1. Visit the SCS Software Download web page: StaticControl.com/SoftwareDownloads.aspx 2. Download the SMP ID Programmer ZIP file to your PC, and run the setup.exe file. 3. Follow the on-screen prompts to install the software to your PC. The application will automatically open when complete. Operation 1. Open the SMP ID Programmer application. CTC034-031-5-WW EM Aware Monitor, Event, Field & Ionization, Modbus Output CTC061-5-242-WW WS Aware Monitor, Modbus Output, with Standard Remotes CTC061-5-243-WW WS Aware Monitor, Modbus Output, with Big Brother Remotes CTC062-5-242-WW WS Aware Monitor, Modbus Output, with Standard Remotes CTC062-5-243-WW WS Aware Monitor, Modbus Output, with Big Brother Remotes CTC065-5-WW Ground Master Monitor, Modbus Output Packaging 1 SMP Device ID Programmer with RJ45 Cable 1 USB Cable, 1 m Length 1 Driver Installation CD SCS - 926 JR Industrial Drive, Sanford, NC 27332 • (919) 718-0000 • Website: StaticControl.com TB-9058 Page 1 of 3 January 2016 © 2016 DESCO INDUSTRIES, INC. Employee Owned 2. Use the drop down menu to select the COM port that is associated with your SMP Device ID Programmer. 3. Use the Device drop down menu to select the SCS monitor type that you choose to program. Select “WS&GM” if programming the WS Aware Monitor or Ground Master Monitor. Select “EM_AWARE” if programming the EM Aware Monitor. 4. Connect the programmer’s RJ45 plug into the SCS monitor. Power the monitor using its 12VDC power adapter. 5. Click the Scan button, and the monitor’s current ID number will populate into the MB Address field. 6. Enter the desired ID number into the “New MB Address” field. It may be any number between 1-4. 7. Click the Change button, and a confirmation prompt will appear. 8. Click the OK button. 9. Click the Scan button again to confirm that the new ID number is programmed into the monitor. 10. The monitor is now ready to be deployed and connected to your SMP system. Repeat steps 3-9 if more monitors need to be programmed. SCS - 926 JR Industrial Drive, Sanford, NC 27332 • (919) 718-0000 • Website: StaticControl.com TB-9058 Page 2 of 3 © 2016 DESCO INDUSTRIES, INC. Employee Owned Specifications Size 1.7" L x 2.2" W x 1.0" H (43 mm L x 56 mm W x 25 mm H) Weight .1 lbs. (.05 kg) Limited Warranty, Warranty Exclusions, Limit of Liability and RMA Request Instructions See the SCS Warranty http://staticcontrol.descoindustries.com/warranty.aspx Operating System Compatibility Windows XP or newer Made in Taiwan SCS - 926 JR Industrial Drive, Sanford, NC 27332 • (919) 718-0000 • Website: StaticControl.com TB-9058 Page 3 of 3 © 2016 DESCO INDUSTRIES, INC. Employee Owned
770036 价格&库存
很抱歉,暂时无法提供与“770036”相匹配的价格&库存,您可以联系我们找货
