W
Made in the United
States of America
Description
Desco’s clear Dissipative Cart Covers are made from a dissipative (1 x 109 to < 1 x 1011
ohms per ANSI/ESD STM11.11) and low charging 0.012 inch polyvinylchloride (PVC)
material. They are designed to be used with ESD susceptible items and allow contents of the
carts to be identified without opening the cover. The covers include zippered front flaps that
may be left open for access to the cart when the flap is opened. The flap can be locked (lock
not included) closed to prevent tampering with cart contents when not in use. A dissipative
document pocket is located on the outside of the cart to store documents.
Electrical Properties
H
1 x 109 to < 1 x 1011 ohms per ANSI/ESD STM11.11
Surface Resistance
Physical Properties
Color
Emboss Pattern
Clear*
Non-Embossed
Gauge
Tensile
Elongation
Tear
0.012" ± 0.002" (~1/80", 12 mils)
1000lb/in2 minimum
150% minimum
125 lb/in minimum
ASTM D412, Die C
ASTM D412, Die C
ASTM D624, Die C
Chemical Resistance
D
Resistant to degradation by inorganic acids, organic acids, reducing agents, detergent
solutions, alcohols, aliphatic hydrocarbons, mineral oil, amines, and aldehydes.
Item
Description (DxWxH)
68200
Cart Cover, 23" x 32" x 41"
68201
Cart Cover, 24" x 36" x 62"
68202
Cart Cover, 24" x 48" x 62"
*Color and texture may vary between lots and mills. Original product color may change over time.
Unless otherwise noted, tolerance ±10%
Specifications and procedures subject to change without notice.
Document Holder Pocket
Zipper
Cart Cover, Dissipative
DESCO WEST: 3651 WALNUT AVE., CHINO, CA 91710 WEB SITE: Desco.com
PHONE (909) 627-8178 FAX (909) 627-7449
DESCO EAST: ONE COLGATE WAY, CANTON, MA 02021-1407
PHONE (781) 821-8370 FAX (781) 575-0172
© 2014 DESCO INDUSTRIES INC.
Employee Owned
DRAWING NUMBER
68200
DATE:
August
2014
很抱歉,暂时无法提供与“68201”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+4070.018051+526.51897
