35879
35879
    DESCO
    ASSYWORKSTATIONORGANIZERBLANK
35879 数据手册
DESCRIPTION • • • • 7 1/4" • • 16 1/4" • • • • 35879 in use “Specifications and procedures subject to change without notice.” Replaceable top insert for Menda Workstation Organizers 35871, 35872, & 35873. Insert is a single sheet allowing you to customize for your workstation needs. A sharp utility knife and a metal straight edge is recommended for customizing the insert. Caution should be taken whenever using sharp objects; obtain guidance from facility's safety officer. Dimensions: 16 1/4" x 7 1/4", +/- 1/16" tolerance Made from an Extruded Conductive polypropylene PlastekTM material, making it ideal to properly set up and standardize an ESD workstation. Conductive 10E2 - 10E4 ohms per ANSI/ESD S11.11 - material provides reliable path to ground. Superior strength and durability; made from extruded, high impact polypropylene materials. Chemical and moisture resistant. Flaps are scored for accurate and easy folding Item ships unassembled Made in America “It should be understood that any object, item, material or person could be a source of static electricity in the work environment. Removal of unnecessary nonconductors, replacing nonconductive materials with dissipative or conductive materials and grounding all conductors are the principle methods of controlling static electricity in the workplace, regardless of the activity.” [ESD Handbook ESD TR20.20-2008 section 2.4 Sources of Static Electricity] BLANK INSERT, WORKSTATION ORGANIZER 3651 WALNUT AVENUE, CHINO, CA 91710 PHONE: (909) 627-2453 FAX: (951) 755-8848 WEBSITE: MendaPump.com © 2011 DESCO INDUSTRIES INC. Employee Owned MADE IN AMERICA DRAWING NUMBER 35879 DATE January 2011
35879 价格&库存
很抱歉,暂时无法提供与“35879”相匹配的价格&库存,您可以联系我们找货
