47512
47512
    DESCO
    CARD HOLDER STAT DISS 100PK
47512 数据手册
FEATURES • Dissipative 6 mil clear polycarbonate film • ESD Susceptibility Symbol identifies contents that should be opened only when grounded in ESD protected areas • Full adhesive back with peel-off liner • Packaged 100 items/pack • Made in America Electrical Properties: Static Decay: Surface Resistance: Triboelectric Charge Generation: < 1.0 sec. 109 - 1010 Ohms Negligible per FTMS 101C, M4046 per ESD S4.1 per EIA-541 3,400 PSI @ 73°F Negligible 2000-3000 PSI 500-800% 20-30 cm/kg 200 grams 10,000-15,000 PSI 0.3 Kinetic, Film to Film per FTMS per ASTM per ASTM per ASTM per ASTM per ASTM per ASTM Specifications: Use this card holder on bin boxes, material handling and storage containers Polycarbonate Compatibility: Corrosivity: Tensile Strength: Elongation @ Break: Ball Burst Impact Strength: Tear Propagation: Modulus of Elasticity: Coefficient of Friction: • • • • ITEM DESCRIPTION 47510 Dissipative Card Holder, 4” x 2” 47511 Dissipative Card Holder, 4” x 5” 47512 Dissipative Card Holder, 4-1/8” x 7” 101C-3005 D-882 D882 D-3420 D-1938 D-882A D-1894 Humidity independent N-Octanoic Acid Free Does not promote corrosion Has no measurable outgassing Meets or exceeds the requirements of MIL-B-81705C, Type II Made in America Dissipative Card Holder, With ESD Susceptibility Symbol PROTEKTIVE PAK 14040 CENTRAL AVENUE, CHINO, CA 91710 PHONE (909) 627-2578, FAX (909) 363-7331 www.protektivepak.com © 2005 DESCO INDUSTRIES INC. Employee Owned DRAWING NUMBER 47510 DATE: 3/05
47512 价格&库存
很抱歉,暂时无法提供与“47512”相匹配的价格&库存,您可以联系我们找货
