Features
Made in the
• Provides physical protection, with conductive material
United States of America
providing reliable path-to-ground
• Many sizes available
• Shipped knocked-down; easy to assemble
• Conductive 1 x 102 to < 1 x 105 ohms material provides reliable path-to-ground
• Superior strength and durability; made from extruded, high impact polypropylene materials
• Chemical and moisture resistant
• Ideal for use where corrugated and/or paper products cannot be used
• Economical alternative to injection molded products
• Reusable, ensuring best value*
• Made in the United States of America
D
L
Specifications
W
Item
L x W x D (IN)
L x W x D (MM)
38900
12 x 2 x 4
305 x 51 x 102
38901
12 x 4 x 4
305 x 102 x 102
38902
12 x 6 x 4
305 x 152 x 102
38903
12 x 8 x 4
305 x 203 x 102
38904
18 x 4 x 4
457 x 102 x 102
38905
18 x 6 x 4
457 x 152 x 102
38906
38907
18 x 8 x 4
24 x 4 x 4
457 x 203 x 102
610 x 102 x 102
38908
24 x 6 x 4
610 x 152 x 102
38909
18 x 2 x 4
457 x 51 x 102
Properties
Resin Type
Conductive
Surface Resistance
Humidity Independent
Temperature Tolerance
Melting Point
Typical Values
Polypropylene
Permanently
1 x 102 to < 1 x 105 ohms per ANSI/ESD STM11.11
and ESD TR53
Yes
-17° F to +230° F
324° F
RoHS 2 and REACH Compliance Statement
None of the RoHS 2 restricted materials or REACH substances of very high concern as of 2013/06/20
are intentionally added in manufacturing this product. Ref: European Union Directive 2011/65/EU and
Regulation (EC) No. 1907/2006/CE. See Protektive Pak Limited Warranty at ProtektivePak.com.
Per Packaging standard ANSI/ESD S54.1 section 6.1. Inside an ESD Protected Area “Packaging used
within an EPA (that satisfies the minimum requirements of ANSI/ESD S20.20) shall be:
1. Low charge generation.
2. Dissipative or conductive materials for intimate contact.”
38910
24 x 2 x 4
610 x 51 x 102
38911
12 x 12 x 4
305 x 305 x 102
Unless otherwise noted, tolerance ± 10%
38912
18 x 12 x 4
457 x 305 x 102
Specifications and procedures subject to change without notice.
Plastek™ Open Bin Boxes
PROTEKTIVE PAK
13520 MONTE VISTA AVENUE, CHINO, CA 91710
PHONE (909) 627-2578
ProtektivePak.com
© 2014 DESCO INDUSTRIES INC.
Employee Owned
DRAWING NUMBER
38900
DATE:
January
2014
很抱歉,暂时无法提供与“38904”相匹配的价格&库存,您可以联系我们找货
