Features
Made in the
United States of America
D
L
Item
Size I.D. - L x W x D
37033 7" x 5" x 1-1/2"
37034
37035
37036
37037
W
• Economical, efficient method of shipping or storing circuit boards and
other static sensitive electronic devices
• BLACK low density conductive convoluted polyurethane foam,
< 1 x 105 ohms laminated to the top and fitted in the bottom
• BLACK low density conductive convoluted foam is permanently
conductive; will not lose electrical properties or fade
• Provides ESD shielding with lid closed, “Faraday cage” effect restricts
electrostatic charges and discharges to exterior
• Corrugated material is constructed from a unique buried conductive
layer of impregnated corrugated fiberboard with a static dissipative
surface
• BLACK convoluted foam minimizes movement and reduces stress from
physical shock
• Corrugated material is made from 100% recycled material and is 100%
recyclable
• No assembly required
• Made in the United States of America
7" x 5" x 2-1/2"
10-1/2" x 8-1/2" x 1-1/2"
10-1/2" x 8-1/2" x 2-1/2"
12-1/2" x 10-1/2" x 2-1/2"
Specifications
Properties
Surface Resistance
Corrosivity
Sloughing Test
Recyclability
Biodegradability
Typical Values
Meets ANSI/ESD S20.20 and Packaging standard ANSI/ESD S541
1 x 106 to < 1 x 109 ohms
Contains 1-3 ppm reducible sulfur
Negligible surface damage at 10 cycles and
很抱歉,暂时无法提供与“37034”相匹配的价格&库存,您可以联系我们找货
