37037
37037
    DESCO
    CBSHPPR12-1/2X10-1/2X2-1/2
37037 数据手册
Features Made in the United States of America D L Item Size I.D. - L x W x D 37033 7" x 5" x 1-1/2" 37034 37035 37036 37037 W • Economical, efficient method of shipping or storing circuit boards and other static sensitive electronic devices • BLACK low density conductive convoluted polyurethane foam, < 1 x 105 ohms laminated to the top and fitted in the bottom • BLACK low density conductive convoluted foam is permanently conductive; will not lose electrical properties or fade • Provides ESD shielding with lid closed, “Faraday cage” effect restricts electrostatic charges and discharges to exterior • Corrugated material is constructed from a unique buried conductive layer of impregnated corrugated fiberboard with a static dissipative surface • BLACK convoluted foam minimizes movement and reduces stress from physical shock • Corrugated material is made from 100% recycled material and is 100% recyclable • No assembly required • Made in the United States of America 7" x 5" x 2-1/2" 10-1/2" x 8-1/2" x 1-1/2" 10-1/2" x 8-1/2" x 2-1/2" 12-1/2" x 10-1/2" x 2-1/2" Specifications Properties Surface Resistance Corrosivity Sloughing Test Recyclability Biodegradability Typical Values Meets ANSI/ESD S20.20 and Packaging standard ANSI/ESD S541 1 x 106 to < 1 x 109 ohms Contains 1-3 ppm reducible sulfur Negligible surface damage at 10 cycles and
37037 价格&库存
很抱歉,暂时无法提供与“37037”相匹配的价格&库存,您可以联系我们找货
