4013
4013
    SCS
    CONTAINER COND ROUND W/LID 1.81"
4013 数据手册
Round Containers with Covers Data Sheet These Velostat containers are injection-molded in a variety of shapes and sizes. They are ideal for staticsafe storage, kitting, and in-process handling and transporting of static-sensitive assemblies and devices. Product No. Diameter 4011 4012 4013 4014 4015 2.38” 3.38” 1.81” 4.06” 3.81” (6,0 cm) (8,6 cm) (4,6 cm) (10,3 cm) (9,7 cm) Height 0.88” 0.88” 4.0” 2.34” 4.69” (2,2 cm) (2,2 cm) (10,2 cm) (6,0 cm) (11,9 cm) All dimensions are referenced from the inside bottom of the container and are nominal dimensions. Typical Property Test Method 4550 Compound / 1801 Sheet Stock Typical Value * 4520 Compound / 1840 Sheet Stock Typical Value ** Hardness ASTM D2240 58-62 Shore D 67-71 Shore D Heat Deflection Temp. ASTM D648 38°- 43°C @ 264 psi 100°C @ 66 psi 50°C @ 264 psi Water Absorbtion ASTM 570 .1 - .2% .1 - .2% Vicat Softening ASTM D1525 88°- 92°C 148°C Flammability ASTM D635 4.5 - 5.5 cm/min 2 cm/min Thermal Conductivity ASTM C117 .15 - .25 BTU/hr*ft2*°F/ft 0.19 BTU/hr*ft2*°F/ft Impact Resistance Notched Izod ASTM D256 2.9 - 3.7 ft-lbs/in @ 72°F 0.6 - 1.3 ft-lbs/in @ 25°F 8 - 10 ft-lbs/in @ 72°F 7 - 9 ft-lbs/in @ 25°F Maximum Temp. Exposure 3M 150°F 180°F Tensile Strength ASTM D638 1700 - 2000 psi 2800 - 3000 psi Flex Modulus ASTM D790 40,000-50,000 psi 130,000-150,000 psi Mold Shrinkage ASTM 955 15 - 20 mil/in 10 - 20 mil/in Electrical Conductance Volume Conductive ASTM D991 < 500 ohms/cm < 500 ohms/cm Resistant Severe Attack Moderate Attack Slight Attack Slight Attack Resistant Resistant Severe Attack Moderate Attack Slight Attack Moderate Attack Resistant Severe Attack Moderate Attack Slight Attack Slight Attack Resistant Resistant Severe Attack Moderate Attack Slight Attack Moderate Attack Chemical Resistance Alcohol Aromatic Hydrocarbons Aliphatic Hydrocarbons Concentrated Acids Concentrated Alkalines Dilute Acids Dilute Alkalines Kerosene Keytones (Acetone) Mineral Oil Oil and Gasoline ASTM D543 *Velostat polyethylene technical data for 4550 Resin; 1801; 4251-4254ASnap on Covers. **Velostat polypropylene technical data for 4520 Resin; 1840; 4011-4016 Round Containers and Lids; 4021-4025 Hinged Containers; 4031-4032 (tray only); 4061-4063 Trays; 4321-4333ASlip-in Dividers; 4400ASeries Tote Boxes and 4215-4236AInsert Covers; 4430-4431 Trays and 4420-4421 Covers; 4451-4457 Parts Bin; 4458-4459 Parts Drawer and Divider; 5701 Single Device Carriers; and 8520-8523 Single Card Carriers. Limited Warranty – 3M expressly warrants that for a period of one year from the date of purchase, 3M static control products will be free of defects in materials (parts) and workmanship (labor). Defects occurring during the warranty period will be repaired or products will be replaced at 3M’s option and expense, if 3M receives notice during the warranty period. Defective products must be returned to 3M with proof of purchase date. Warranty Exclusions – THE FOREGOING EXPRESS WARRANTYIS MADE IN LIEU OF ALLOTHER PRODUCT WARRANTIES, EXPRESS AND IMPLIED, INCLUDING FITNESS AND MERCHANTIBILITY. The express warranty will not apply to defects or damage due to accidents, neglect, misuse, alterations, operator error, or failure to properly maintain, clean, or repair products. Limit of Liability – In no event will 3M or Seller be responsible or liable for special, incidental, or consequential losses or damages, whether based in tort or contract. Fulfillment of 3M’s warranty obligations will be Customer’s exclusive remedy and 3M’s and Seller’s limit of liability for any breach of warranty or otherwise. For your nearest distributor or to order, call 1-800-328-1368 Electronic Handling & Protection Division 6801 River Place Blvd. Austin, TX 78726-9000 © 3M December 1996 Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: SCS: 4013
很抱歉,暂时无法提供与“4013”相匹配的价格&库存,您可以联系我们找货
    库存:888
