37630
37630
    DESCO
    TOTENESTINGSTACKTOP18X12X6
37630 数据手册
Features ------- D -- -- -- W -- -- -- - -- -- -L -- -- -- -- • Used to transport or store ESD Sensitive items • Rotating steel wire arms- when rotated in, totes are stackable even full of product, saving valuable space and enhancing productivity when moved • Rotating steel wire arms - when rotated out, totes can nest, saving space when when storing • Great container for Kanban RoHS Compliance Statement None of the following materials are intentionally added in manufacturing this product: lead, mercury, cadmium, hexavalent chromium, polybrominated biphenyls (PBB) or polybrominated diphenyl ethers (PBDE) as outlined in the Directive 2002/95/EC Article 4.1. See Protektive Pak Inc. letter on-line at ProtektivePak.com. Item No. O.D. Top Size - L x W x D I.D. Bottom Size - L x W x D 37630 18 x 12 x 6 15 x 8-3/4 x 6 37631 27-1/4 x 12 x 6 24-1/2 x 8-3/4 x 6 37632 27-1/4 x 18 x 6 24-1/2 x 15 x 6 SPECIFICATIONS Properties Electrostatic Decay Surface Resistivity Surface Resistivity, Low R.H. Cut-off High-Voltage Discharge Resistance Static Shielding Charged Device Model (CDM) Safety Current-Carrying Hazard Corrosivity Antistat Transfer Water & Isopropyl Alcohol Extraction Tests for Antistat Permanence Sloughing Test Recyclability Biodegradability Volume Conductivity Shelf Life Typical Values 0.01 seconds at 72°F and 11.8% R.H. 107 - 108 ohms/sq. after 11 days at 68°F and 12% R.H. for surface. 103 - 104 ohms/sq. for buried shielding layer 4% R.H. Failure rate 0/5 (no oxide damage in five consecutive tests) 99.9% attenuation at 10kV; 99.6% attenuation at 30kV RTG >107 ohms at 86% R.H. or less 103 mA at 110V; 103 mA at 220V Contains 1-3 ppm reducible sulfur No transfer Surface resistivity 108 - 109 ohms/square at 74°F and 36% R.H. Negligible surface damage at 10 cycles and
37630 价格&库存
很抱歉,暂时无法提供与“37630”相匹配的价格&库存,您可以联系我们找货
