FEATURES
Dissipative 6 mil clear polycarbonate film
ESD Susceptibility Symbol identifies contents
that should be opened only when grounded in
ESD protected areas
Full adhesive back with peel-off liner
Packaged 100 items/pack
Made in America
Electrical Properties:
Static Decay:
Surface Resistance:
Triboelectric Charge Generation:
< 1.0 sec.
109 - 1010 Ohms
Negligible
per FTMS 101C, M4046
per ESD S4.1
per EIA-541
3,400 PSI @ 73°F
Negligible
2000-3000 PSI
500-800%
20-30 cm/kg
200 grams
10,000-15,000 PSI
0.3 Kinetic, Film to Film
per FTMS
per ASTM
per ASTM
per ASTM
per ASTM
per ASTM
per ASTM
Specifications:
Use this card holder on bin
boxes, material handling and
storage containers
Polycarbonate Compatibility:
Corrosivity:
Tensile Strength:
Elongation @ Break:
Ball Burst Impact Strength:
Tear Propagation:
Modulus of Elasticity:
Coefficient of Friction:
ITEM
DESCRIPTION
47510
Dissipative Card Holder, 4” x 2”
47511
Dissipative Card Holder, 4” x 5”
47512
Dissipative Card Holder, 4-1/8” x 7”
101C-3005
D-882
D882
D-3420
D-1938
D-882A
D-1894
Humidity independent
N-Octanoic Acid Free
Does not promote corrosion
Has no measurable outgassing
Meets or exceeds the requirements of MIL-B-81705C, Type II
Made in America
Dissipative Card Holder, With ESD Susceptibility Symbol
PROTEKTIVE PAK
14040 CENTRAL AVENUE, CHINO, CA 91710
PHONE (909) 627-2578, FAX (909) 363-7331
www.protektivepak.com
© 2005 DESCO INDUSTRIES INC.
Employee Owned
DRAWING NUMBER
47510
DATE:
3/05
很抱歉,暂时无法提供与“47510”相匹配的价格&库存,您可以联系我们找货
