09203
09203
    DESCO
    WRST STRP ADJ ELST ONYX 12' ANG
09203 数据手册
CAM CENTER OPEN CAM CENTER CLOSED Made in the United States of America A. Magnetic connection creates a superior connection with wrist band. Maintains 1-5 pound release. B. Small cam lock, allows material replacement. 300 series stainless steel. C. Large cam lock, allows size adjustment, maintains electrical continuity even when open. 300 series stainless steel. Floating cam lock allows wide opening for easy adjustment and secures material down against base plate when closed. D. 300 series stainless steel backplate (0.016" thick). Manufacturing date code is stamped into stainless steel backplate.   CIRCUMFERENCE ITEM DESCRIPTION MIN MAX E. Black (onyx) translucent cap. F. Knit elastic band material of gray; .875" (22mm) wide and 0.10" (2.5mm) thick. 50 strands of textured polyester, 36 strands of lycra spandex and 14 strands of silver plated polypropylene yarn. Made with pure silver irreversibly bound to fibers providing both antimicrobial and anti-odor properties. Outer surface of gray fibers act as an insulator. G. The conductive silver plated polypropylene (see G) represents 13.5% of the material by weight. The 14 strands of conductive polypropylene are randomly knit on the inner surface of the material and are electrically isolated from the outer surface (gray side). H. Underwriters Laboratory listing 90P1. WIDTH 09183 Band only 2.5" (63.5mm) 13" (330mm) .875" (22mm) 09184 Band w/ 6' Cord 2.5" (63.5mm) 13" (330mm) .875" (22mm) 09185 Band w/ 12' Cord 2.5" (63.5mm) 13" (330mm) .875" (22mm) 09202 Band w/ 6' Angle Cord 2.5" (63.5mm) 13" (330mm) .875" (22mm) 09203 Band w/ 12' Angle Cord 2.5" (63.5mm) 13" (330mm) .875" (22mm) Unless otherwise noted, tolerance ±10% Specifications and procedures subject to change without notice. JEWEL® MAGSNAP ELASTIC WRIST STRAPS DESCO WEST: 3651 WALNUT AVE., CHINO, CA 91710 WEB SITE: Desco.com PHONE (909) 627-8178 DESCO EAST: ONE COLGATE WAY, CANTON, MA 02021-1407 PHONE (781) 821-8370 © 2013 DESCO INDUSTRIES INC. Employee Owned DRAWING NUMBER 09183 DATE: August 2013
09203 价格&库存
很抱歉,暂时无法提供与“09203”相匹配的价格&库存,您可以联系我们找货
