19866
19866
    DESCO
    COIL CORD DUAL SNAPONE 4MM 18'
19866 数据手册
Dual Wire Coil Cord provides redundancy; even if one conductor is severed, operator has reliable path-to-ground with other wire. Park-it Hole "If any part of the loop should open (become disconnected or have out of limit resistance), the circuit will go into the alarm state" [ref TR20.20], nonetheless, due to the redundancy inherent in the dual wire wrist strap design, the operator will continue to be grounded via the second intact wire. Per ESD Handbook TR20.20 section 5.3.9.2.2 Dual Conductor Resistance Continuous Monitors, "This type of monitor is used with a two wire (dual conductor) wrist strap. The wrist strap assembly consists of a two-wire ground cord and a wristband that has two isolated halves. When a person is wearing the wrist strap properly, the monitor measures the loop resistance consisting of one wire of the ground cord, one-half of the wristband, the person's skin, the second half of the wristband, and a second wire in the ground cord. If any part of the loop should open (become disconnected or have out of limit resistance), the circuit will go into the alarm state. ESD Handbook TR 20.20 paragraph 5.3.2.4.4 Test Frequency "Because wrist straps have a finite life, it is important to develop a test frequency that will guarantee integrity of the system. Typical test programs recommend that wrist straps that are used daily should be tested daily. However, if the products that are being produced are of such value that knowledge of a continuous, reliable ground is needed, and then continuous monitoring should be considered or even required" Continuous Monitors pay for themselves improving quality, productivity, eliminating wrist strap daily testing and test result logging. Per ESD-S1.1 paragraph 6.1.3 Frequency of Functional Testing "Daily [Wrist Strap] testing may be omitted if constant monitoring is used." Improve wrist strap contact with Reztore™ ESD Hand Lotion *U.S. Patents 6,052,053 and 6,205,408 • Used with resistive loop technology continuous monitor, continuously verifies the proper resistance to ground of the operator • Coil cord with molded 1 Megohm current limiting resistor on both ground paths to protect user from shock due to inadvertent contact with line voltage • 28 gauge wire • 3.5mm phono plug connector • Single (Snap-One™) snap head allows operators to quickly and easily attach and detach the cord from the wristband (Use Desco wristband) • Park-it feature on Snap-One™ molded snap head provides convenient park station for cord when not in use. Simply insert phono plug into hole to allow for hanging cord at workbench. • Custom manufactured right angle mono-plug reduces chance of accidental disconnects providing more secure ground connection • Patented* dual wire technology • Superior resistor connection strain relief Superior reliability. Greatly exceeds ESD S1.1 Bending Life Test. Tested at over 200,000 cycles vs. the 16,000 requirement • Superior warranty - See details of 1 year Limited Warranty at http://www.Desco.com/Warranty.aspx Use patented* Dual Wire Wrist Strap with Desco Dual Wire Continuous Monitor ITEM REF. # 19695 SE4333 19696 SE4343 DESCRIPTION 6' Coil Cord, 4mm female snaps, right angle mono plug 12' Coil Cord, 4mm female snaps, right angle mono plug 19866 SE4353 18' Coil Cord, 4mm female snaps, right angle mono plug COIL CORD, DUAL-WIRE, SNAP-ONE™, RIGHT ANGLE MONO PLUG DESCO WEST: 3651 WALNUT AVE., CHINO, CA 91710 WEB SITE: Desco.com PHONE (909) 627-8178 FAX (909) 627-7449 DESCO EAST: ONE COLGATE WAY, CANTON, MA 02021-1407 PHONE (781) 821-8370 FAX (781) 575-0172 ©2009 DESCO INDUSTRIES INC. Employee Owned DRAWING NUMBER 19695 DATE: March 2009
19866 价格&库存
很抱歉,暂时无法提供与“19866”相匹配的价格&库存,您可以联系我们找货
  • 1+132.394631+17.13963
库存:50
19866
  • 1+134.703841+17.43858
库存:50
