STATFREE® ESD ULTRA CLEAR BAG
Specifications:
Electrical Properties
Surface Resisitance:
(Interior and Exterior)
Charge Generation:
Teflon
Quartz
Typical Value
Test Procedures/Method
< 1 x 1011 ohms
Per ANSI/ESD STM11.11
-0.10 (nC/in2)
+0.10 (nC/in2)
Modified Incline Plane
Nominal .0035" (.0889mm) ±10%
Nominal -0" / + .125"
Nominal ± .125"
>90 (%)
>8 (lbs/in)
>5,300 (MD/TD, psi)
>25 lbs
0.35
MIL-STD-3010, 1003
Physical Properties:
STATFREE®
STATIC DISSIPATIVE
CLEAR MOISTURE BARRIER BAG
MADE IN U.S.A.
DESCO INDUSTRIES INC.
CHINO, CA CANTON, MA
MARLBORO, MA
Date & Lot Code
Printed for QC
Traceablility
Side Weld Seals 3/8 in.
Thickness
Width (Inside Dimensions)
Length (Inside Dimensions)
Light Transmission
Heat Seal
Tensile Strength
Puncture Res.
MVTR
STM D-1003
375°F, .75 sec 60 psi
ASTM D-882
MIL-STD-3010, 2065
ASTM F-1249
Chemical Properties
Polycarbonate compatible: Contains no Amines, Amides, or N-Octanoic Acid.
Bag is free of amines, N-octanoic acid, silicones and heavy metals.
Static Dissipative
Coating
48 GA Polyester
Static Dissipative
Permastat™ PE
Mixed Unsortable Plastic Scrap
7
Mixed unsortable plastic scrap shall contain assorted plastics
of multiple grades that are co-extruded, bonded or laminated
together which are unsortable into individual grades
Desco’s bags are recyclable
Statshield® bags are packaged 100 per package in an oversized shielding bag.
Shelf life of bags is minimum one year in normal indoor storage conditions.
ANSI/ESD S541 Section 6.1 Inside an EPA
“Packaging used within an EPA (that satisfies the minimum requirements of ANSI/ESD S20.20) shall be:
• Low charge generation
• Dissipative or conductive materials for intimate contact
RoHS 2 and REACH Statement
None of the RoHS 2 restricted materials or REACH substances of very high concern as
of 2012/12/19 are intentionally added in manufacturing this product. Ref: European Union
Directive 2011/65/EU and Regulation (EC) No. 1907/2006/CE.
See Desco Limited Warranty at Desco.com.
Meets ANSI/ESD S20.20 and Packaging standard ANSI/ESD S541 tested per ANSI/ESD STM11.11
Statshield® and Statfree® are Registered Trademarks of Desco Industries Inc.
STATFREE® ESD ULTRA CLEAR BAG, .0035" (.0889mm)
DESCO WEST: 3651 WALNUT AVE., CHINO, CA 91710 WEB SITE: Desco.com
PHONE (909) 627-8178
DESCO EAST: ONE COLGATE WAY, CANTON, MA 02021-1407
PHONE (781) 821-8370
© 2013 DESCO INDUSTRIES INC.
Employee Owned
Made in the
United States of America
Specifications and procedures subject to change without notice.
DRAWING
NUMBER
13878
DATE:
July
2013
很抱歉,暂时无法提供与“13873”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+2.881991+0.37201
