13877
13877
    DESCO
    BAG DISS CLEAR 12X18
13877 数据手册
STATFREE® ESD ULTRA CLEAR BAG Specifications: Electrical Properties Surface Resisitance: (Interior and Exterior) Charge Generation:  Teflon  Quartz Typical Value Test Procedures/Method < 1 x 1011 ohms Per ANSI/ESD STM11.11 -0.10 (nC/in2) +0.10 (nC/in2) Modified Incline Plane Modified Incline Plane Nominal .0035" (.0889mm) ±10% Nominal -0" / + .125" Nominal ± .125" >90 (%) >8 (lbs/in) >5,300 (MD/TD, psi) >25 lbs 0.35 MIL-STD-3010, 1003 Physical Properties: STATFREE® STATIC DISSIPATIVE CLEAR MOISTURE BARRIER BAG MADE IN U.S.A. DESCO INDUSTRIES INC. CHINO, CA  CANTON, MA MARLBORO, MA Date & Lot Code Printed for QC Traceablility Side Weld Seals 3/8 in. Thickness Width (Inside Dimensions) Length (Inside Dimensions) Light Transmission Heat Seal Tensile Strength Puncture Res. MVTR STM D-1003 375°F, .75 sec 60 psi ASTM D-882 MIL-STD-3010, 2065 ASTM F-1249 Chemical Properties Polycarbonate compatible: Contains no Amines, Amides, or N-Octanoic Acid. Bag is free of amines, N-octanoic acid, silicones and heavy metals. Static Dissipative Coating 48 GA Polyester Static Dissipative Permastat™ PE Mixed Unsortable Plastic Scrap 7 Mixed unsortable plastic scrap shall contain assorted plastics of multiple grades that are co-extruded, bonded or laminated together which are unsortable into individual grades Desco’s bags are recyclable Statshield® bags are packaged 100 per package in an oversized shielding bag. Shelf life of bags is minimum one year in normal indoor storage conditions. ANSI/ESD S541 Section 6.1 Inside an EPA “Packaging used within an EPA (that satisfies the minimum requirements of ANSI/ESD S20.20) shall be: • Low charge generation • Dissipative or conductive materials for intimate contact RoHS 2 and REACH Statement None of the RoHS 2 restricted materials or REACH substances of very high concern as of 2012/12/19 are intentionally added in manufacturing this product. Ref: European Union Directive 2011/65/EU and Regulation (EC) No. 1907/2006/CE. See Desco Limited Warranty at Desco.com. Meets ANSI/ESD S20.20 and Packaging standard ANSI/ESD S541 tested per ANSI/ESD STM11.11 Statshield® and Statfree® are Registered Trademarks of Desco Industries Inc. STATFREE® ESD ULTRA CLEAR BAG, .0035" (.0889mm) DESCO WEST: 3651 WALNUT AVE., CHINO, CA 91710 WEB SITE: Desco.com PHONE (909) 627-8178 DESCO EAST: ONE COLGATE WAY, CANTON, MA 02021-1407 PHONE (781) 821-8370 © 2013 DESCO INDUSTRIES INC. Employee Owned Made in the United States of America Specifications and procedures subject to change without notice. DRAWING NUMBER 13878 DATE: July 2013
13877 价格&库存
很抱歉,暂时无法提供与“13877”相匹配的价格&库存,您可以联系我们找货
