AS06608PS-WR-R
AS06608PS-WR-R
    PUIAUDIO
    SPEAKER 8OHM 4W 95DB 66MM
AS06608PS-WR-R 数据手册
SPECIFICATIONS PARAMETERS RATED INPUT POWER MAX INPUT POWER IMPEDANCE OUTPUT SPL @ 1W/0.5M (AT 1.0, 1.4, 1.7, 2.0 kHz) DISTORTION (MAX.) RESONANT FREQUENCY FREQUENCY RANGE HOUSING MATERIAL CONE MATERIAL MAGNET MATERIAL OPERATING TEMPERATURE WEIGHT VALUES UNITS 4 5 8 15% W W OHM 95 3 5% 230 20% 230 ~ 12,000 METAL TREATED PAPER FERRITE -20 ~ +50 204 THIS DOCUMENT CONTAINS DATA PROPRIETARY TO PROJECTS UNLIMITED, INC. ANY USE OR REPRODUCTION, IN ANY FORM, WITHOUT PRIOR WRITTEN PERMISSION OF PROJECTS UNLIMITED, INC. IS PROHIBITED. REVISION HISTORY LTR DESCRIPTION DATE APPROVED A B C D E F RELEASED FROM ENGINEERING REVISED RESONANT FREQ. TOLERANCE REVISED TO INVENTOR 3-D DRAWING TEMPLATE ADDED NOTE 5 REVISED HOLE TO HOLE DIMENSION REVISED ROHS STATUS REVISED TERMINAL DIRECTION 9/12/2005 3/16/2007 1/19/2009 8/12/2011 9/13/2013 9/13/2013 10/22/2020 R.W. B.R. B.R. M.L. M.L. M.V. 2003, Projects Unlimited Inc. dBA Hz Hz C grams 29 6x4.6 (4) 3 4 75.5 60 66.3 61.5 NOTES: 1. ALL DIMENSIONS ARE IN MILLIMETERS. 2. SPECIFICATIONS SUBJECT TO CHANGE OR WITHDRAWL WITHOUT NOTICE. 3. THIS PART IS RoHS 2011/65/EU COMPLIANT. 4. CONE HAS BEEN TREATED FOR WATER RESISTANCE. 5. BASE SPEAKER PUI# AS06608PS-R. UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN MILLIMETERS, TOLERANCES ARE 0.5 AND ANGLES ARE 3 . SIZE A3 AS06608PS-WR-R.idw Designed by Date Checked by Date Approved by J.A.F. 9/12/2005 B.R. 9/12/2005 E.P. Date Drawn Date 9/12/2005 1/19/2009 AS06608PS-WR-R Speaker Edition Sheet - 1/1
AS06608PS-WR-R 价格&库存
很抱歉,暂时无法提供与“AS06608PS-WR-R”相匹配的价格&库存,您可以联系我们找货
AS06608PS-WR-R
    • 1+52.39202
    • 10+47.12262
    • 100+43.44653
    • 500+40.29114
    • 1000+32.72028
    库存:8
