Metal-Out Static Shielding Bag 2100R/2110R
The transparent, puncture resistant metal-out static shielding bag is designed
to provide static safe packaging for the shipment and/or storage of ESD
sensitive items including outside ESD protected areas. The metal layer is
positioned near the outer surface to help reduce voltage retention and enhance
static decay. Bags are printed with an ESD protective symbol and a lot code for
traceability. Open Top (2100R) and ZipTop (2110R) styles are available. The
bags are heat sealable.
SCS Static Shielding Bags are manufactured from a top coat, metal, polyester,
polyethylene laminate. The proprietary top coating is designed to protect
the metal layer. Polyester dielectric, in concert with the metal layer, provides
shielding of Electrostatic Discharge (ESD) to minimize the penetration of
electric fields and discharges.
Open
OpenTop
TopBag
Bag
ZipTop
ZipTopBag
Bag
Meets ANSI/ESD S20.20, Packaging standard ANSI/ESD S541, and
Static Control Bag ANSI/ESD S11.4 Level 3
Physical
Typical Value
Testing Method
Tensile Strength
8000 PSI, 55 MPa
ASTM D882
Puncture Resistance
24 lbs, 106 N
MIL-STD-3010C Method 2065
Seal Strength
18 lbs, 80 N
ASTM D882
Thickness
3.2 mils, 0.081 mm +/-10%
MIL-STD-3010C Method 1003
Marking Adhesion
Pass
IPC-TM-650 2.4.1
Transparency
37%
Tobias
Electrical
Typical Value
Testing Method
ESD Shielding
很抱歉,暂时无法提供与“2111215”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 100+9.76596100+1.26169
