SMT-0440-T-R
SMT-0440-T-R
    PUIAUDIO
    AUDIOMAGNETICXDCR2-4VSMD
SMT-0440-T-R 数据手册
This document contains data proprietary to PUI Audio Inc. Any use or reproduction, in any form, without prior written permission of PUI Audio Inc. is prohibited. ©2017, PUI Audio Inc. Data Sheet SMT-0440-T-R Though extremely small, the SMT-0440 series transducers are constructed almost exactly the same as electro-mechanical transducers three times their size. What this means for users is that PUI Audio is leveraging their decades of triedand-true transducer design into each and every one of these, for the designer’s piece of mind. The 4mm square by 2mm high SMT-0440-T-R top-firing electro-mechanical transducer features a minimum SPL of 70 dBA at 10cm with only 3V (0-peak) input at 4 kHz. Features: • Ultra-small design for wearable devices • High output in a small, lightweight package • Pick-and-place and reflow compatible Specifications Parameters Rated Voltage Operating Voltage Range Impedance Minimum SPL (Rated voltage @ 10cm) Resonant Frequency Max Current Draw (Rated voltage, 50% duty cycle, at resonant frequency) Housing Material Terminal Material Weight Operating Temperature Storage Temperature Values 3 2~4 17 ± 3 Units Volts 0-peak Volts 0-peak Ohms 70 4,000 ±500 dBA Hz 90 LCP Tin-plated Brass 0.1 -20 ~ +70 -30 ~ +80 mA Grams °C °C PUI Audio, Inc. A Projects Unlimited Company, 3541 Stop Eight Road, Dayton, OH 45414 Tel: (937) 415-5901 Fax: (937) 415-5925 This document contains data proprietary to PUI Audio Inc. Any use or reproduction, in any form, without prior written permission of PUI Audio Inc. is prohibited. ©2017, PUI Audio Inc. Measurement Method (3V0-p sine-sweep) Frequency Response (measured with 3V0-p @ 10cm) Recommended Drive Circuit PUI Audio, Inc. A Projects Unlimited Company, 3541 Stop Eight Road, Dayton, OH 45414 Tel: (937) 415-5901 Fax: (937) 415-5925 This document contains data proprietary to PUI Audio Inc. Any use or reproduction, in any form, without prior written permission of PUI Audio Inc. is prohibited. ©2017, PUI Audio Inc. Recommended Reflow Profile Reliability Testing Type of Test High Temperature Test Low Temperature Test Humidity Test Test Specifications 96 hours at +70°C ± 2°C followed by two hours in normal room temperature 96 hours at -20°C ± 2°C followed by two hours in normal room temperature 25 ± 2 ℃ at 90-95% RH for 5 hr, then to 55 ± 2℃ at 90-95% RH for 5hr, then to 25°C ± 2°C at 9095% RH for 0.5hr, 10 cycles The part shall be subjected to 5 cycles using the following procedure followed by two hours at room temperature: Temperature Cycle Testing 10 to 50 to 10 Hz in three perpendicular Vibration Test directions for two hours each. Drop transducer from a 70cm height onto a 10mm Drop Test thick wooden board in three directions. After each test, the part’s SPL, frequency response, and current draw shall meet specifications. PUI Audio, Inc. A Projects Unlimited Company, 3541 Stop Eight Road, Dayton, OH 45414 Tel: (937) 415-5901 Fax: (937) 415-5925 This document contains data proprietary to PUI Audio Inc. Any use or reproduction, in any form, without prior written permission of PUI Audio Inc. is prohibited. ©2017, PUI Audio Inc. Dimensions Recommended PCB Land Pattern PUI Audio, Inc. A Projects Unlimited Company, 3541 Stop Eight Road, Dayton, OH 45414 Tel: (937) 415-5901 Fax: (937) 415-5925 This document contains data proprietary to PUI Audio Inc. Any use or reproduction, in any form, without prior written permission of PUI Audio Inc. is prohibited. ©2017, PUI Audio Inc. Packaging PUI Audio, Inc. A Projects Unlimited Company, 3541 Stop Eight Road, Dayton, OH 45414 Tel: (937) 415-5901 Fax: (937) 415-5925 This document contains data proprietary to PUI Audio Inc. Any use or reproduction, in any form, without prior written permission of PUI Audio Inc. is prohibited. ©2017, PUI Audio Inc. Revision - Specifications Revisions Description Released from Engineering Note: 1. Unless otherwise specified: A. All dimensions are in millimeters. B. Default tolerances are ±0.5mm and angles are ±3°. 2. Specifications subject to change or withdrawal without notice. 3. This part is RoHS 2011/65/EU Compliant. PUI Audio, Inc. A Projects Unlimited Company, 3541 Stop Eight Road, Dayton, OH 45414 Tel: (937) 415-5901 Fax: (937) 415-5925 Date 11/06/2014
SMT-0440-T-R 价格&库存
很抱歉,暂时无法提供与“SMT-0440-T-R”相匹配的价格&库存,您可以联系我们找货
SMT-0440-T-R
  • 3000+18.260873000+2.36253
库存:4079
SMT-0440-T-R
  • 1+35.904841+4.64525
  • 10+28.2243710+3.65158
  • 25+25.7191425+3.32746
  • 50+23.9907150+3.10384
  • 100+22.39709100+2.89766
  • 250+22.35113250+2.89172
库存:4079
SMT-0440-T-R
    • 1+15.53040
    • 200+6.01560
    • 500+5.79960
    • 1000+5.70240
