AI-3035-TWT-3V-R
AI-3035-TWT-3V-R
    PUIAUDIO
    插件
    AUDIO PIEZO INDICATOR 2-5V TH
AI-3035-TWT-3V-R 数据手册
SPECIFICATIONS PARAMETERS RATED VOLTAGE OPERATING VOLTAGE RANGE RATED CURRENT (MAX) MINIMUM SPL @ 10 CM RESONANT FREQUENCY TONE OR PULSE RATE OPERATING TEMPERATURE STORAGE TEMPERATURE HOUSING MATERIAL TERMINAL MATERIAL WEIGHT VALUES UNITS 3 2~5 9 100 3,500 500 CONTINUOUS -30 ~ +70 -40~ +85 PBT Sn PLATED COPPER 8 Vdc Vdc mA dBA Hz 0 pulse/sec THIS DOCUMENT CONTAINS DATA PROPRIETARY TO PROJECTS UNLIMITED, INC. ANY USE OR REPRODUCTION, IN ANY FORM, WITHOUT PRIOR WRITTEN PERMISSION OF PROJECTS UNLIMITED, INC. IS PROHIBITED. 2003, Projects Unlimited Inc. REVISION HISTORY LTR DESCRIPTION DATE APPROVED A B C D E RELEASED FROM ENGINEERING REVISED BODY HEIGHT DIMENSION REVISED TO INVENTOR 3-D DRAWING TEMPLATE REVISED HEIGHT AND STAND-OFF DIMENSIONS NEGATIVE POLARITY MARK REMOVED POSITIVE POLARITY MARK RECESSED REVISED HOUSING DIMENSIONS 3/22/2006 4/18/2008 6/14/2008 9/23/2011 7/6/2017 8/21/2017 B.R. B.R. M.L. M.V. M.L. C C grams 1 7 SOUND EMISSION HOLE 30 15 0.8 (2) WASH TAB 19.3 4.5 EPOXY POTTING 20.1 NOTES: 1. ALL DIMENSIONS ARE IN MILLIMETERS. UNLESS OTHERWISE SPECIFIED: 2. SPECIFICATIONS SUBJECT TO CHANGE OR WITHDRAWL WITHOUT NOTICE. DIMENSIONS ARE IN MILLIMETERS, 3. THIS PART IS RoHS 2011/65/EU COMPLIANT. TOLERANCES ARE 0.5 AND ANGLES ARE 3 . SIZE A3 AI-3035-TWT-3V-R.idw Designed by Date Checked by Date Approved by T.G. 3/22/2006 B.R. 3/22/2006 E.P. Date Drawn Date 3/22/2006 6/14/2008 AI-3035-TWT-3V-R Indicator Edition Sheet - 1/1
AI-3035-TWT-3V-R 价格&库存
很抱歉,暂时无法提供与“AI-3035-TWT-3V-R”相匹配的价格&库存,您可以联系我们找货
AI-3035-TWT-3V-R
    • 1+36.07200
    • 10+31.09320
    • 30+28.04760
    • 100+25.50960
    AI-3035-TWT-3V-R
    • 1+22.51472
    • 10+20.30699
    • 100+18.73450
    • 500+17.35987
    • 1000+14.10034
    库存:71
