AI-1223-TWT-12V-R
AI-1223-TWT-12V-R
    PUIAUDIO
    AUDIO MAGNETIC IND 8-16V TH
AI-1223-TWT-12V-R 数据手册
SPECIFICATIONS PARAMETERS RATED VOLTAGE OPERATING VOLTAGE RANGE RATED CURRENT (MAX) MINIMUM SPL @ 10 CM RESONANT FREQUENCY TONE OR PULSE RATE OPERATING TEMPERATURE STORAGE TEMPERATURE HOUSING MATERIAL TERMINAL MATERIAL WEIGHT VALUES UNITS 12 8 ~ 16 30 85 2,300 400 CONTINUOUS -30 ~ +80 -40 ~ +85 PBT Sn PLATED RED COPPER 2 Vdc Vdc mA dBA Hz 0 pulse /sec THIS DOCUMENT CONTAINS DATA PROPRIETARY TO PUI AUDIO, INC. ANY USE OR REPRODUCTION, IN ANY FORM, WITHOUT PRIOR WRITTEN PERMISSION OF PUI AUDIO, INC. IS PROHIBITED. REVISION HISTORY LTR DESCRIPTION DATE APPROVED A B C D E F RELEASED FROM ENGINEERING REMOVED LEAD FREE NOTE ADDED RoHS NOTE REVISED DIMENSION SIZE AND STYLE REVISED SOUND HOLE AND TEMPERATURE REVISED TO INVENTOR 3-D DRAWING TEMPLATE REVISED HOUSING MATERIAL REVISED TEMPERATURE RATINGS 8/10/2004 8/5/2005 11/28/2005 5/11/2010 6/30/2010 9/25/2012 2/14/2020 B.R. B.R. B.R. B.R. B.R. M.L. 2010, PUI AUDIO Inc. C C grams 6 9.5 0.2 0.5 WASH TAB 2.6 SOUND EMISSION HOLE POSITIVE LEAD 7.6 2 0.6 (2) 12 POTTING 0.2 NOTES: 1. ALL DIMENSIONS ARE IN MILLIMETERS. 2. SPECIFICATIONS SUBJECT TO CHANGE OR WITHDRAWL WITHOUT NOTICE. 3. THIS PART IS RoHS 2015/863/EU COMPLIANT. 4. WAVE SOLDER AND WASH ALLOWED. UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN MILLIMETERS, TOLERANCES ARE 0.5 AND ANGLES ARE 3 . SIZE A3 AI-1223-TWT-12V-R.idw Designed by Date R.A.C. 8/10/2004 Checked by Date Approved by R.W. Date Drawn Date 8/10/2004 6/30/2010 AI-1223-TWT-12V-R Indicator Edition Sheet - 1/1
AI-1223-TWT-12V-R 价格&库存
很抱歉,暂时无法提供与“AI-1223-TWT-12V-R”相匹配的价格&库存,您可以联系我们找货
AI-1223-TWT-12V-R
    • 1+23.83728
    • 10+21.45251
    • 100+19.81754
    • 500+18.30753
    • 1000+14.95427
    库存:81
