AI-1440-TWT-24V-2-R
AI-1440-TWT-24V-2-R
    PUIAUDIO
    DC Buzzer Single Tone 4kHz Piezo 6 ~ 30V 87dB @ 24V, 10cm
AI-1440-TWT-24V-2-R 数据手册
SPECIFICATIONS PARAMETERS RATED VOLTAGE OPERATING VOLTAGE RANGE RATED CURRENT (MAX) MINIMUM SPL @ 10 CM RESONANT FREQUENCY TONE OR PULSE RATE OPERATING TEMPERATURE STORAGE TEMPERATURE HOUSING MATERIAL TERMINAL MATERIAL WEIGHT VALUES UNITS 24 6 ~ 30 Vdc Vdc 18 87 4,000 500 CONTINUOUS -30 ~ +70 -40 ~ +85 NORYL Sn PLATED COPPER 1 mA dBA Hz 0 pulse /sec THIS DOCUMENT CONTAINS DATA PROPRIETARY TO PROJECTS UNLIMITED, INC. ANY USE OR REPRODUCTION, IN ANY FORM, WITHOUT PRIOR WRITTEN PERMISSION OF PROJECTS UNLIMITED, INC. IS PROHIBITED. 2003, Projects Unlimited Inc. REVISION HISTORY LTR DESCRIPTION DATE APPROVED A B RELEASED FROM ENGINEERING REVISED TO INVENTOR 3-D DRAWING TEMPLATE ADDED NOTE 4 REVISED SOUND HOLE DIAMETER AND TEMPERATURE SPECIFICATIONS 10/18/2006 11/16/2007 4/9/2012 B.R. B.R. 2/21/2020 M.V. C C C grams 5.5 13.8 7.5 WASH TAB 7.6 1.5 1.4 SOUND EMISSION HOLE 0.7 (2) POTTING NOTES: 1. ALL DIMENSIONS ARE IN MILLIMETERS. 2. SPECIFICATIONS SUBJECT TO CHANGE OR WITHDRAWL WITHOUT NOTICE. 3. THIS PART IS RoHS 2002/95/EC COMPLIANT. 4. INTERNAL WIRE IS 0.15mm ENAMELLED COATED WITH A660 ADHESIVE OVER SOLDER JOINTS. UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN MILLIMETERS, TOLERANCES ARE 0.5 AND ANGLES ARE 3 . SIZE A3 AI-1440-TWT-24V-2-R.idw Designed by Date Checked by Date Approved by J.D. 10/18/2006 B.R. 10/18/2006 R.W. Date Drawn Date 10/18/2006 11/15/2007 AI-1440-TWT-24V-2-R Indicator Edition Sheet - 1/1
AI-1440-TWT-24V-2-R 价格&库存
很抱歉,暂时无法提供与“AI-1440-TWT-24V-2-R”相匹配的价格&库存,您可以联系我们找货
AI-1440-TWT-24V-2-R
    • 1+38.92320
    • 10+33.36120
    • 30+30.05640
    • 100+26.71920
