SPECIFICATIONS
PARAMETERS
RATED VOLTAGE
OPERATING VOLTAGE RANGE
RATED CURRENT (MAX)
MINIMUM SPL @ 10 CM
RESONANT FREQUENCY
TONE OR PULSE RATE
OPERATING TEMPERATURE
STORAGE TEMPERATURE
HOUSING MATERIAL
TERMINAL MATERIAL
WEIGHT
VALUES
UNITS
12
8 ~ 15
30
85
2,200 300
CONTINUOUS
-30 ~ +70
-40 ~ +85
NORYL
Sn PLATED
COPPER
5
Vdc
Vdc
mA
dBA
Hz
0 pulse/sec
THIS DOCUMENT CONTAINS DATA PROPRIETARY TO
PUI AUDIO, INC. ANY USE OR REPRODUCTION, IN
ANY FORM, WITHOUT PRIOR WRITTEN PERMISSION
OF PUI AUDIO, INC. IS PROHIBITED.
0.2
LTR
DESCRIPTION
DATE
APPROVED
A
B
C
D
E
RELEASED FROM ENGINEERING
REVISED RoHS STATEMENT
REVISED DIMENSION SIZE AND STYLE
REVISED TERMINAL MATERIAL
REVISED TO INVENTOR 3-D DRAWING TEMPLATE
REVISED TEMPERATURE RATINGS
8/19/2004
5/27/2005
11/21/2005
3/20/2006
10/10/2007
2/25/2020
B.R.
B.R.
B.R.
B.R.
M.L.
2010, PUI AUDIO Inc.
C
C
grams
14
16
REVISION HISTORY
0.2
7
WASH TAB
POTTING
1.5
7.6
0.2
0.6
3.2 SOUND
EMISSION HOLE
NOTES:
1. ALL DIMENSIONS ARE IN MILLIMETERS.
2. SPECIFICATIONS SUBJECT TO CHANGE OR WITHDRAWL
WITHOUT NOTICE.
3. THIS PART IS RoHS 2015/863/EU COMPLIANT.
UNLESS OTHERWISE
SPECIFIED:
DIMENSIONS ARE IN
MILLIMETERS,
TOLERANCES
ARE 0.5 AND
ANGLES ARE 3 .
SIZE
A3
AI-1622-TWT-12V-R.idw
Designed by
Date
R.A.C.
8/19/2004
Checked by
Date
Approved by
R.W.
Date
Drawn Date
8/20/2004 10/10/2007
AI-1622-TWT-12V-R
Indicator
Edition
Sheet
1/1
很抱歉,暂时无法提供与“AI-1622-TWT-12V-R”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+40.896281+5.31018
