SPECIFICATIONS
PARAMETERS
RATED VOLTAGE
OPERATING VOLTAGE RANGE
RATED CURRENT (MAX)
MINIMUM SPL @ 10 CM
RESONANT FREQUENCY
TONE OR PULSE RATE
OPERATING TEMPERATURE
STORAGE TEMPERATURE
HOUSING MATERIAL
TERMINAL MATERIAL
WEIGHT
VALUES
UNITS
12
3 ~ 20
Vdc
Vdc
15
85
3,100 500
CONTINUOUS
-30 ~ +70
-40 ~ +85
NORYL
Sn PLATED
COPPER
3
mA
dBA
Hz
0 pulse /sec
THIS DOCUMENT CONTAINS DATA PROPRIETARY TO
PROJECTS UNLIMITED, INC. ANY USE OR
REPRODUCTION, IN ANY FORM, WITHOUT PRIOR
WRITTEN PERMISSION OF PROJECTS UNLIMITED,
INC. IS PROHIBITED.
2003, Projects Unlimited Inc.
REVISION HISTORY
LTR
DESCRIPTION
DATE
A
B
C
D
E
F
G
H
RELEASED FROM ENGINEERING
ADDED DIMENSION
REMOVED LEAD FREE NOTE ADDED RoHS
REVISED TERMINAL MATERIAL
ADDED EPOXY SEAL NOTE
REVISED BODY HEIGHT DIMENSION
REVISED TO INVENTOR 3-D DRAWING TEMPLATE
ADDED NOTE 4
REVISED TEMPERATURE SPECIFICATIONS
8/23/2004
8/27/2004
8/10/2005
11/28/2006
3/7/2007
4/7/2008
12/21/2008
2/17/2012
2/24/2020
C
C
APPROVED
R.W.
R.W.
B.R.
B.R.
B.R.
M.L.
M.V.
grams
9.7
23.4
3.7 SOUND
EMISSION HOLE
0.8 (2)
15
WASH TAB
NOTES:
6.5
1. ALL DIMENSIONS ARE IN MILLIMETERS.
2. SPECIFICATIONS SUBJECT TO CHANGE OR WITHDRAWL
WITHOUT NOTICE.
3. THIS PART IS RoHS 2002/95/EC COMPLIANT.
4. PART IS NOT WASHABLE.
UNLESS OTHERWISE
SPECIFIED:
DIMENSIONS ARE IN
MILLIMETERS,
TOLERANCES
ARE 0.5 AND
ANGLES ARE 3 .
SIZE
A3
AI-2331-TWT-R.idw
Designed by
Date
R.A.C.
8/23/2004
Checked by
Date
Approved by
R.W.
Date
Drawn Date
8/23/2004 12/21/2008
AI-2331-TWT-R
Indicator
Edition
Sheet
1/1
很抱歉,暂时无法提供与“AI-2331-TWT-R”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+47.457501+6.13936
