AI-2429-TWT-R
AI-2429-TWT-R
    PUIAUDIO
    MIC_D23.8X16MM_TM
    压电蜂鸣器 12VDC MIC_D23.8X16MM_TM
AI-2429-TWT-R 数据手册
AI-2429-TWT-R 24mm Indicator 3541 Stop Eight Road • Dayton, Ohio 45414 Product Overview • 24mm diameter, 3-20 VDC self-drive indicator • 100 dBA minimum output (12 VDC @ 10 cm) and 2,900 Hz con%nuous tone • ABS housing withstands Wave soldering temperatures • Removable wash tag preserves performance SPL vs Voltage (measured @ 30 cm) PUI Audio Inc. engages in continuous product improvement. All specifications are subject to change without notice. www.puiaudio.com. Copyright © 2015. Last Revised 10/15. AT-1438-TWT-R AI-2429-TWT-R 40mm Speaker 24mm Indicator Mechanical and Environment Testing Test Description Test Condition High Temperature 80°C (±2°C) with random humidity for 96 hours Low Temperature Drop Test -40°C (±2°C) with random humidity for 96 hours 40°C (±2°C) with 90% to 95% relative humidity for 96 hours 0.75 mm movement modulated at 10-55 Hz for 3 hours 100 cm free fall onto wood board, 10 cycles Temperature Cycle Test -30°C to 80°C, 100 cycles Humidity Vibration Wave Solder Profile After tests, part shall rest for 2 hours. Parts are then tested for clean, pure tones. Frequency Response and SPL Measurement Setup Temperature Cycle Test Graph PUI Audio Inc. engages in continuous product improvement. All specifications are subject to change without notice. www.puiaudio.com. Copyright © 2015. Last Revised 10/15. SPECIFICATIONS PARAMETERS VALUES UNITS RATED VOLTAGE OPERATING VOLTAGE RANGE RATED CURRENT (MAX) MINIMUM SPL @ 10 CM 12 3 ~ 20 8 100 2,900 ± 500 Vdc Vdc mA dBA Hz 0 pulse/sec RESONANT FREQUENCY TONE OR PULSE RATE OPERATING TEMPERATURE STORAGE TEMPERATURE HOUSING MATERIAL TERMINAL MATERIAL WEIGHT CONTINUOUS -20 ~ +70 -40 ~ +80 ABS Sn PLATED RED COPPER 6 THIS DOCUMENT CONTAINS DATA PROPRIETARY TO PROJECTS UNLIMITED, INC. ANY USE OR REPRODUCTION, IN ANY FORM, WITHOUT PRIOR WRITTEN PERMISSION OF PROJECTS UNLIMITED, INC. IS PROHIBITED. ©2003, Projects Unlimited Inc. A B C DESCRIPTION DATE APPROVED RELEASED FROM ENGINEERING REMOVED LEAD FREE ADDED RoHS REVISED TO INVENTOR 3-D DRAWING TEMPLATE REVISED TERMINAL MATERIAL 8/19/2004 8/10/2005 1/28/2008 2/7/2011 B.R. M.L. °C °C grams 6 23.8 REVISION HISTORY LTR 16 REMOVABLE WASH TAB 15 0.8 0.1 (2) 5.8 SOUND EMISSION HOLE NOTES: 1. ALL DIMENSIONS ARE IN MILLIMETERS. 2. SPECIFICATIONS SUBJECT TO CHANGE OR WITHDRAWL WITHOUT NOTICE. 3. THIS PART IS RoHS 2002/95/EC COMPLIANT. UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN MILLIMETERS, TOLERANCES ARE ±0.5 AND ANGLES ARE ±3°. SIZE A3 AI-2429-TWT-R.idw Designed by Date R.A.C. 8/19/2004 Checked by Date Approved by R.W. Date Drawn Date 8/19/2004 1/28/2008 AI-2429-TWT-R Indicator Edition Sheet - 1/1
AI-2429-TWT-R 价格&库存
很抱歉,暂时无法提供与“AI-2429-TWT-R”相匹配的价格&库存,您可以联系我们找货
AI-2429-TWT-R
  • 1+43.347931+5.60772
  • 10+33.0868210+4.28029
  • 25+29.8694025+3.86407
  • 50+27.6863250+3.58165
  • 100+25.69825100+3.32446
  • 250+23.33359250+3.01856
  • 500+21.72247500+2.81014
  • 1000+20.247531000+2.61933
库存:20878
AI-2429-TWT-R
  • 1+30.08558
  • 10+27.03432
  • 100+24.94114
  • 500+23.13955
  • 1000+18.82822
库存:16
