SPECIFICATIONS
PARAMETERS
RATED VOLTAGE
OPERATING VOLTAGE RANGE
RATED CURRENT (MAX)
MINIMUM SPL @ 10 CM
RESONANT FREQUENCY
TONE OR PULSE RATE
OPERATING TEMPERATURE
STORAGE TEMPERATURE
HOUSING MATERIAL
TERMINAL MATERIAL
WEIGHT
VALUES
UNITS
9
3 ~ 20
15
105
3,500 500
CONTINUOUS
-20 ~ +60
-25 ~ +65
ABS
LEAD WIRES
7.3
Vdc
Vdc
mA
dBA
Hz
0 pulse/sec
THIS DOCUMENT CONTAINS DATA PROPRIETARY TO
PROJECTS UNLIMITED, INC. ANY USE OR
REPRODUCTION, IN ANY FORM, WITHOUT PRIOR
WRITTEN PERMISSION OF PROJECTS UNLIMITED,
INC. IS PROHIBITED.
REVISION HISTORY
LTR
DESCRIPTION
DATE
APPROVED
A
B
RELEASED FROM ENGINEERING
REVISED TO INVENTOR 3-D DRAWING TEMPLATE
REVISED MAX CURRENT
3/22/2006
2/15/2008
3/10/2020
B.R.
M.V.
2003, Projects Unlimited Inc.
C
C
grams
14
3
5.5 SOUND
EMISSION HOLE
100
5
5
2
RED (+)
51.4
45
31
BLACK (-)
UL1095 AWG #28
3.2
3.6
NOTES:
1. ALL DIMENSIONS ARE IN MILLIMETERS.
2. SPECIFICATIONS SUBJECT TO CHANGE OR WITHDRAWL
WITHOUT NOTICE.
3. THIS PART IS RoHS 2002/95/EC COMPLIANT.
2
UNLESS OTHERWISE
SPECIFIED:
DIMENSIONS ARE IN
MILLIMETERS,
TOLERANCES
ARE 0.5 AND
ANGLES ARE 3 .
SIZE
A3
AI-3135-TF-LW100-R.idw
Designed by
Date
Checked by
Date
Approved by
T.G.
3/22/2006
B.R.
3/22/2006
E.P.
Date
Drawn Date
3/22/2006 2/15/2008
AI-3135-TF-LW100-R
Indicator
Edition
Sheet
1/1
很抱歉,暂时无法提供与“AI-3135-TF-LW100-R”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+33.80339
- 3+31.24055
- 5+28.67771
- 10+26.11487
- 20+24.05036
- 50+21.97398
