AI-4228-TF-LW140-3-R
    PUIAUDIO
    BUZZER PIEZO 12V 41.8MM CHASSIS
AI-4228-TF-LW140-3-R 数据手册
SPECIFICATIONS PARAMETERS RATED VOLTAGE OPERATING VOLTAGE RANGE RATED CURRENT (MAX) MINIMUM SPL @ 10 CM RESONANT FREQUENCY TONE OR PULSE RATE OPERATING TEMPERATURE STORAGE TEMPERATURE HOUSING MATERIAL TERMINAL MATERIAL WEIGHT VALUES UNITS 12 1.5 ~ 20 Vdc Vdc 10 106 2,800 500 CONTINUOUS -20 ~ +60 -30 ~ +70 ABS LEAD WIRE 15 mA dBA Hz 0 pulse/sec THIS DOCUMENT CONTAINS DATA PROPRIETARY TO PROJECTS UNLIMITED, INC. ANY USE OR REPRODUCTION, IN ANY FORM, WITHOUT PRIOR WRITTEN PERMISSION OF PROJECTS UNLIMITED, INC. IS PROHIBITED. REVISION HISTORY LTR DESCRIPTION DATE APPROVED A B C D E RELEASED FROM ENGINEERING REVISED COLOR OF WIRE LEADS REVISED GAUGE OF WIRE LEADS REVISED TO INVENTOR 3-D DRAWING TEMPLATE ADD NOTE 4 REVISED VOLTAGE RANGE 11/8/2005 10/11/2007 7/3/2008 1/14/2011 8/26/2014 2/24/2020 R.W. B.R. B.R. B.R. M.V. 2003, Projects Unlimited Inc. C C grams 5 10 140 5 UL1007 AWG# 24 5 2 BLACK (-) 60 50 41.8 RED (+) 7.1 SOUND EMISSION HOLE NOTES: 3.5 (2) 16 1. ALL DIMENSIONS ARE IN MILLIMETERS. 2. SPECIFICATIONS SUBJECT TO CHANGE OR WITHDRAWL WITHOUT NOTICE. 3. THIS PART IS RoHS 2011/65/EU COMPLIANT. 4. ALL INTERNAL COMPONENTS UPDATED TO SMD. UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN MILLIMETERS, TOLERANCES ARE 0.5 AND ANGLES ARE 3 . SIZE A3 AI-4228-TF-LW140-3-R.idw Designed by Date Checked by Date Approved by J.A.F. 11/8/2005 B.R. 11/9/2005 E.P. Date Drawn Date 11/9/2004 10/10/2008 AI-4228-TF-LW140-3-R Indicator Edition Sheet - 1/1
AI-4228-TF-LW140-3-R 价格&库存
很抱歉,暂时无法提供与“AI-4228-TF-LW140-3-R”相匹配的价格&库存,您可以联系我们找货
  • 1+31.51227
  • 10+28.37771
  • 100+26.19080
  • 500+24.31631
  • 1000+19.72381
库存:11
  • 1+45.739361+5.91100
  • 10+34.9712010+4.51940
  • 25+31.5716825+4.08008
  • 90+27.4770490+3.55092
  • 180+25.53521180+3.29997
  • 270+24.47804270+3.16335
  • 540+22.79388540+2.94570
  • 1080+21.251501080+2.74638
库存:9995
