SMI-1324-TW-3V-R-T/R
    PUIAUDIO
    BUZZER MAGNETIC 3V 12.8MM SMD
SMI-1324-TW-3V-R-T/R 数据手册
SPECIFICATIONS PARAMETERS VALUES UNITS 3 Vdc RATED VOLTAGE OPERATING VOLTAGE RANGE 2~5 Vdc RATED CURRENT (MAX) 30 mA MINIMUM SPL @ 10 CM 75 dBA 2,400 400 RESONANT FREQUENCY Hz 0 pulse/sec TONE OR PULSE RATE CONTINUOUS -20 ~ +70 OPERATING TEMPERATURE C STORAGE TEMPERATURE -30 ~ +85 C HOUSING MATERIAL PPS TERMINAL MATERIAL Sn PLATED BRASS grams WEIGHT 2 9.8 THIS DOCUMENT CONTAINS DATA PROPRIETARY TO PROJECTS UNLIMITED, INC. ANY USE OR REPRODUCTION, IN ANY FORM, WITHOUT PRIOR WRITTEN PERMISSION OF PROJECTS UNLIMITED, INC. IS PROHIBITED. 2003, Projects Unlimited Inc. 0.3 REVISION HISTORY LTR DESCRIPTION DATE APPROVED A B C RELEASED FROM ENGINEERING REVISED DRAWING TO SHOW POSITIVE MARK REVISED TO INVENTOR 3-D DRAWING TEMPLATE REVISED STORAGE TEMPERATURE 10/18/2006 10/26/2006 6/1/2010 2/27/2020 R.W. B.R. M.V. 0.6 6.5 3 0.3 REMOVABLE WASH TAB 12.8 0.3 2 0.3 2.2 SOUND EMISSION HOLE 12.8 0.3 R0.7 (3) 3.5 EPOXY 0.5 0.1 NOTES: 1. ALL DIMENSIONS ARE IN MILLIMETERS. UNLESS OTHERWISE SPECIFIED: 2. SPECIFICATIONS SUBJECT TO CHANGE OR WITHDRAWL WITHOUT NOTICE. DIMENSIONS ARE IN MILLIMETERS, 3. THIS PART IS RoHS 2002/95/EC COMPLIANT. TOLERANCES ARE 0.5 AND ANGLES ARE 3 . SIZE A3 SMI-1324-TW-3V-R.idw Designed by Date Checked by Date Approved by Date Drawn Date J.D. 9/18/2006 B.R. 9/18/2006 R.W. 9/18/2006 6/1/2010 SMI-1324-TW-3V-R Indicator Edition Sheet - 1/1
SMI-1324-TW-3V-R-T/R 价格&库存
很抱歉,暂时无法提供与“SMI-1324-TW-3V-R-T/R”相匹配的价格&库存,您可以联系我们找货
  • 450+36.21619450+4.67521
  • 900+34.04484900+4.39491
库存:946
  • 1+62.593511+8.08030
  • 10+49.3404310+6.36944
  • 25+44.9956025+5.80856
  • 50+42.0025550+5.42218
  • 100+41.67091100+5.37937
库存:946
