AI-4328-P-C120D-R
AI-4328-P-C120D-R
    PUIAUDIO
    AC, DC Buzzer Single Tone 2.8kHz Piezo 30 ~ 120V 98dB @ 110V, 10cm
AI-4328-P-C120D-R 数据手册
SPECIFICATIONS PARAMETERS RATED VOLTAGE OPERATING VOLTAGE RANGE RATED CURRENT (MAX) MINIMUM SPL @ 10 CM RESONANT FREQUENCY TONE OR PULSE RATE OPERATING TEMPERATURE STORAGE TEMPERATURE HOUSING MATERIAL TERMINAL MATERIAL WEIGHT VALUES UNITS 110 30 ~ 120 17 98 2,800 500 CONTINUOUS -20 ~ +60 -30 ~ +70 ABS Ni PLATED BRASS 43 Vac/Vdc Vac/Vdc mA dBA Hz 0 pulse/sec THIS DOCUMENT CONTAINS DATA PROPRIETARY TO PROJECTS UNLIMITED, INC. ANY USE OR REPRODUCTION, IN ANY FORM, WITHOUT PRIOR WRITTEN PERMISSION OF PROJECTS UNLIMITED, INC. IS PROHIBITED. REVISION HISTORY LTR DESCRIPTION DATE APPROVED A B C D E RELEASED FROM ENGINEERING REVISED TONE OR PULSE RATE REVISED OPERATING VOLTAGE RANGE REVISED TO INVETOR 3-D DRAWING TEMPLATE REVISED OPERATING VOLTAGE RANGE REVISED RATED VOLTAGE 3/22/2006 1/29/2007 11/30/2007 3/7/2008 4/27/2012 2/24/2020 R.W. B.R. B.R. M.L. M.V. 2003, Projects Unlimited Inc. C C grams 10.5 20 13 43 8 8.5 6.5 28 35.7 7.7 33 NOTES: 1. ALL DIMENSIONS ARE IN MILLIMETERS. 2. SPECIFICATIONS SUBJECT TO CHANGE OR WITHDRAWL WITHOUT NOTICE. 3. THIS PART IS RoHS 2002/95/EC COMPLIANT. UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN MILLIMETERS, TOLERANCES ARE 0.5 AND ANGLES ARE 3 . SIZE A3 AI-4328-P-C120D-R.idw Designed by Date Checked by Date Approved by Date Drawn Date T.G. 3/22/2006 B.R. 3/22/2006 E.P. 3/22/2006 3/7/2008 AI-4328-P-C120D-R Indicator Edition Sheet - 1/1
AI-4328-P-C120D-R 价格&库存
很抱歉,暂时无法提供与“AI-4328-P-C120D-R”相匹配的价格&库存,您可以联系我们找货
