AB3526B-LW100-R
AB3526B-LW100-R
    PUIAUDIO
    PIEZO CERAMIC BENDER 35MM 30V
AB3526B-LW100-R 数据手册
SPECIFICATIONS PARAMETERS RESONANT FREQUENCY RESONANT IMPEDANCE (MAX) MAX INPUT VOLTAGE CAPACITANCE @ 1kHZ PLATE MATERIAL OPERATING TEMPERATURE STORAGE TEMPERATURE VALUES 2,600 500 300 30 30,000 30% BRASS -20 ~ +70 -30 ~ +80 UNITS Hz Ohm Vp-p pF C C 35 THIS DOCUMENT CONTAINS DATA PROPRIETARY TO PROJECTS UNLIMITED, INC. ANY USE OR REPRODUCTION, IN ANY FORM, WITHOUT PRIOR WRITTEN PERMISSION OF PROJECTS UNLIMITED, INC. IS PROHIBITED. REVISION HISTORY LTR DESCRIPTION DATE APPROVED A B RELEASED FROM ENGINEERING REVISED CERAMIC AND BRASS PLATE THICKNESS ADDED GLUE REFERENCE TO DRAWING 5/14/2013 2/12/2020 3/2/2020 M.V. M.V. 2003, Projects Unlimited Inc. A 0.1 100 0.53 0.1 0.25 0.05 5 RED (+) BLACK (-) 5 1 UL1571 30AWG MT-EP36 GLUE A ( 12 : 1 ) 25 NOTES: 1. ALL DIMENSIONS ARE IN MILLIMETERS. 2. SPECIFICATIONS SUBJECT TO CHANGE OR WITHDRAWL WITHOUT NOTICE. 3. THIS PART IS RoHS 2011/65/EU COMPLIANT. UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN MILLIMETERS, TOLERANCES ARE 0.5 AND ANGLES ARE 3 . SIZE A3 AB3526B-LW100-R.idw Designed by Date Checked by Date Approved by J.D. 5/14/2013 C.W. 5/17/2013 B.R. Date Drawn Date 5/17/2013 5/14/2013 AB3526B-LW100-R Bender Edition Sheet - 1/1
AB3526B-LW100-R 价格&库存
很抱歉,暂时无法提供与“AB3526B-LW100-R”相匹配的价格&库存,您可以联系我们找货
