AT-1224-TWT-12V-2-R
AT-1224-TWT-12V-2-R
    PUIAUDIO
    AUDIO MAGNETIC XDCR 8-15V TH
AT-1224-TWT-12V-2-R 数据手册
SPECIFICATIONS PARAMETERS RATED VOLTAGE (SQUARE WAVE) OPERATING VOLTAGE RANGE RATED CURRENT (MAX) COIL RESISTANCE MINIMUM SPL @ 10 CM RESONANT FREQUENCY OPERATING TEMPERATURE STORAGE TEMPERATURE HOUSING MATERIAL TERMINAL MATERIAL WEIGHT VALUES UNITS 12 6 ~ 16 40 140 21 85 2,400 500 -30 ~ +80 -40 ~ +85 PBT-Black Au PLATED BRASS 2 Vpk Vpk THIS DOCUMENT CONTAINS DATA PROPRIETARY TO PROJECTS UNLIMITED, INC. ANY USE OR REPRODUCTION, IN ANY FORM, WITHOUT PRIOR WRITTEN PERMISSION OF PROJECTS UNLIMITED, INC. IS PROHIBITED. REVISION HISTORY LTR DESCRIPTION DATE - RELEASED FROM ENGINEERING 2014/07/25 APPROVED 2003, Projects Unlimited Inc. mA OHM dBA Hz C C grams 5.5 POTTING REMOVEABLE TAB 2X 6.5 0.6 0.1 0.2 12 0.3 0.5 NOTES: 1. ALL DIMENSIONS ARE IN MILLIMETERS. 2. SPECIFICATIONS SUBJECT TO CHANGE OR WITHDRAWL WITHOUT NOTICE. 3. THIS PART IS RoHS 2011/65/EU COMPLIANT. 9.5 0.3 UNLESS OTHERWISE SPECIFIED: All PURCHASES ARE SUBJECT TO AND INCORPORATE THE PUI AUDIO TERMS AND CONDITIONS SALE FOUND AT http://www.puiaudio.com /pdf/terms_conditions.pdf (paper copy available upon request). DIMENSIONS ARE IN MILLIMETERS, TOLERANCES ARE 0.5 AND ANGLES ARE 3 . SIZE A3 AT-1224-TWT-12V-2-R.idw Designed by Date Checked by Date Approved by J.D. 7/25/2014 C.W. 7/25/2014 R.W. Date Drawn Date 7/25/2014 7/25/2014 AT-1224-TWT-12V-2-R Transducer (Electro-Mech) Edition Sheet - 1/1
AT-1224-TWT-12V-2-R 价格&库存
很抱歉,暂时无法提供与“AT-1224-TWT-12V-2-R”相匹配的价格&库存,您可以联系我们找货
AT-1224-TWT-12V-2-R
  • 1+9.835671+1.27489
  • 10+7.4268910+0.96267
  • 25+6.6707625+0.86466
  • 50+6.1591450+0.79834
  • 100+5.69818100+0.73860
  • 300+5.05026300+0.65461
  • 500+4.78016500+0.61960
  • 1000+4.441761000+0.57574
  • 5000+3.763775000+0.48786
库存:6434
