SPECIFICATIONS
PARAMETERS
RATED VOLTAGE
OPERATING VOLTAGE RANGE
RATED CURRENT (MAX)
MINIMUM SPL @ 10 CM
RESONANT FREQUENCY
TONE OR PULSE RATE
OPERATING TEMPERATURE
STORAGE TEMPERATURE
HOUSING MATERIAL
TERMINAL MATERIAL
WEIGHT
VALUES
UNITS
6
1.5 ~ 12
9
106
3,300 500
CONTINUOUS
-30 ~ +80
-40 ~ +80
UL94 ABS
LEAD WIRE
14.1
Vdc
Vdc
mA
dBA
Hz
0 pulse /sec
THIS DOCUMENT CONTAINS DATA
PROPRIETARY TO PROJECTS UNLIMITED, INC.
ANY USE OR REPRODUCTION, IN ANY FORM,
WITHOUT PRIOR WRITTEN PERMISSION OF
PROJECTS UNLIMITED, INC. IS PROHIBITED.
2003, Projects Unlimited Inc.
REVISION HISTORY
DESCRIPTION
RELEASED FROM ENGINEERING
REVISED OPERATING VOLTAGE RANGE
REVISED PULSE RATE PER SECOND
REVISED TO INVENTOR 3-D DRAWING TEMPLATE
REVISED WEIGHT
LTR
A
B
C
D
DATE
5/11/2006
11/22/2006
8/16/2007
3/13/2008
2/27/2020
APPROVED
R.W.
R.W.
B.R.
M.V.
C
C
grams
23
3.5
2
50
80 5
UL1007 AWG #26
10 2
BLACK (-)
46
40
RED (+)
9
NOTES:
1. ALL DIMENSIONS ARE IN MILLIMETERS.
2. SPECIFICATIONS SUBJECT TO CHANGE OR WITHDRAWL
WITHOUT NOTICE.
3. THIS PART IS RoHS 2002/95/EC COMPLIANT.
UNLESS OTHERWISE
SPECIFIED:
DIMENSIONS ARE IN
MILLIMETERS,
TOLERANCES
ARE 0.5 AND
ANGLES ARE 3 .
SIZE
A3
X-4033-TF-LW80-R.idw
Designed by
Date
Checked by
Date
Approved by
J.D.
5/11/2006
E.P.
5/11/2006
B.R.
Date
Drawn Date
5/11/2006 3/13/2008
X-4033-TF-LW80-R
Indicator
Edition
Sheet
1/1
很抱歉,暂时无法提供与“X-4033-TF-LW80-R”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+61.44164
- 10+55.32872
- 100+51.01739
- 500+47.34131
- 1000+38.39582
