X-4028-P-C32-R
X-4028-P-C32-R
    PUIAUDIO
    AUDIO PIEZO IND 3-32V PNL MNT
X-4028-P-C32-R 数据手册
SPECIFICATIONS PARAMETERS VALUES UNITS 32 RATED VOLTAGE OPERATING VOLTAGE RANGE 3 ~ 32 RATED CURRENT (MAX) 22 MINIMUM SPL @ 10 CM 105 2,800 500 RESONANT FREQUENCY TONE OR PULSE RATE CONTINUOUS -30 ~ +80 OPERATING TEMPERATURE STORAGE TEMPERATURE -40 ~ +80 HOUSING MATERIAL UL94 ABS TERMINAL MATERIAL Sn PLATED BRONZE 16 WEIGHT Vdc Vdc mA dBA Hz 0 pulse /sec THIS DOCUMENT CONTAINS DATA PROPRIETARY TO PROJECTS UNLIMITED, INC. ANY USE OR REPRODUCTION, IN ANY FORM, WITHOUT PRIOR WRITTEN PERMISSION OF PROJECTS UNLIMITED, INC. IS PROHIBITED. 2003, Projects Unlimited Inc. REVISION HISTORY LTR A B C DESCRIPTION RELEASED FROM ENGINEERING REVISED TO INVENTOR 3-D DRAWING TEMPLATE REVISED PIN LENGTH TO 8.5mm REVISED WEIGHT DATE 1/24/2006 6/1/2010 9/25/2015 2/26/2020 APPROVED B.R. M.L. M.V. C C grams 23 40 38.5 18.9 33.6 40 8.5 7.15 NOTES: 6.1 8.4 4.75 1. ALL DIMENSIONS ARE IN MILLIMETERS. 2. SPECIFICATIONS SUBJECT TO CHANGE OR WITHDRAWL WITHOUT NOTICE. 3. RECOMMENDED PANEL HOLE IS 28MM 0.2MM. 4. THIS PART IS RoHS 2011/65/EU COMPLIANT. UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN MILLIMETERS, TOLERANCES ARE 0.5 AND ANGLES ARE 3 . SIZE A3 X-4028-P-C32-R.idw Designed by Date Checked by Date Approved by Date Drawn Date J.A.F. 1/24/2006 E.P. 1/24/2006 B.R. 1/24/2006 6/1/2010 X-4028-P-C32-R Indicator Edition Sheet - 1/1
X-4028-P-C32-R 价格&库存
很抱歉,暂时无法提供与“X-4028-P-C32-R”相匹配的价格&库存,您可以联系我们找货
