SPECIFICATIONS
PARAMETERS
RATED VOLTAGE
OPERATING VOLTAGE RANGE
RATED CURRENT (MAX)
MINIMUM SPL @ 10 CM
RESONANT FREQUENCY
TONE OR PULSE RATE
OPERATING TEMPERATURE
STORAGE TEMPERATURE
HOUSING MATERIAL
TERMINAL MATERIAL
WEIGHT
VALUES
UNITS
12
6 ~ 16
260
123
2,000/4,000 500
SIREN
-30 ~ +70
-30 ~ +70
UL94 ABS
LEAD WIRES
91.6
Vdc
Vdc
mA
dBA
Hz
3.0 pulse /sec
54.5
THIS DOCUMENT CONTAINS DATA
PROPRIETARY TO PROJECTS UNLIMITED, INC.
ANY USE OR REPRODUCTION, IN ANY FORM,
WITHOUT PRIOR WRITTEN PERMISSION OF
PROJECTS UNLIMITED, INC. IS PROHIBITED.
2003, Projects Unlimited Inc.
REVISION HISTORY
LTR
DESCRIPTION
DATE
APPROVED
A
B
C
D
RELEASED FROM ENGINEERING
REVISED TO INVENTOR 3-D DRAWING TEMPLATE
REVISED LENGTH DIMENSION
REVISED OPERATING TEMPERATURE
REVISED WEIGHT
5/15/2006
3/26/2008
9/1/2011
4/9/2018
2/27/2020
B.R.
B.R.
M.V.
M.V.
C
C
grams
56
41
AWG #20
RED (+)
BLACK (-)
8
3
+1
3 -0
300
18
14.5
6
5
50
1
NOTES:
1. ALL DIMENSIONS ARE IN MILLIMETERS.
2. SPECIFICATIONS SUBJECT TO CHANGE OR WITHDRAWL
WITHOUT NOTICE.
3. THIS PART IS RoHS 2002/95/EC COMPLIANT.
UNLESS OTHERWISE
SPECIFIED:
DIMENSIONS ARE IN
MILLIMETERS,
TOLERANCES
ARE 0.5 AND
ANGLES ARE 3 .
SIZE
A3
XL-5530-LW300-S-R.idw
Designed by
Date
Checked by
Date
Approved by
J.D.
5/15/2006
E.P.
5/15/2006
B.R.
Date
Drawn Date
5/15/2006 3/26/2008
XL-5530-LW300-S-R
Indicator
Edition
Sheet
1/1
很抱歉,暂时无法提供与“XL-5530-LW300-S-R”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+248.825651+32.19224
- 10+192.8924510+24.95579
- 25+175.0256325+22.64424
- 50+162.8591850+21.07019
- 100+151.72505100+19.62969
- 250+141.90941250+18.35977
