SMT-1028-T-R
10 x 10mm
Transducer
3541 Stop Eight Road • Dayton, Ohio 45414
Product Overview
• Top-firing electromechanical transducer designed for 3 to 4.6 Vp-p
• Small 10 x 10mm footprint with surprising 90 dB output
• 2,830 Hz resonant frequency targets most sensi*ve region of human hearing
• Designed for reflow soldering using a lead-free profile
Frequency Response (3.6 Vp-p @ 0.1 meters)
PUI Audio Inc. engages in continuous product improvement. All specifications are subject to change without notice. www.puiaudio.com. Copyright © 2015. Last Revised 12/15.
AT-1438-TWT-R
SMT-1028-T-R
40mm Speaker
10 x 10mm
Transducer
Mechanical and Environment Testing
Test Description
Test Condition
High Temperature
85°C (±2°C) with random humidity for 96 hours
Low Temperature
Drop Test
-40°C (±2°C) with random humidity for 96 hours
25°C to 60°C with 90% to 95% relative humidity
for 12 hours, 10 cycles
1.53 mm movement modulated at 10-55 Hz in 3
directions for 6 hours
120 cm free fall in six directions, 3 cycles
Temperature Cycle Test
-30°C to 70°C, five 90 minute cycles
Humidity
Vibration
Tape Dimensions
Recommended Reflow Profile
Recommended Land Pattern
SPECIFICATIONS
PARAMETERS
VALUES
UNIT
RATED VOLTAGE (SQUARE WAVE)
3.6
3 ~ 4.6
100
18 ± 5
90
2,830 ± 500
Vp-p
Vp-p
OPERATING VOLTAGE RANGE
RATED CURRENT (MAX)
COIL RESISTANCE
MINIMUM SPL @ 10 CM
RESONANT FREQUENCY
OPERATING TEMPERATURE
STORAGE TEMPERATURE
HOUSING MATERIAL
TERMINAL MATERIAL
WEIGHT
THIS DOCUMENT CONTAINS DATA PROPRIETARY
TO PROJECTS UNLIMITED, INC. ANY USE OR
REPRODUCTION, IN ANY FORM, WITHOUT PRIOR
WRITTEN PERMISSION OF PROJECTS UNLIMITED,
INC. IS PROHIBITED.
©2003, Projects Unlimited Inc.
A
B
DATE
RELEASED FROM ENGINEERING
REVISED TERMINAL MATERIAL
REVISED TO INVENTOR 3-D DRAWING TEMPLATE
8/30/2005
1/20/2006
11/6/2007
APPROVED
B.R.
B.R.
D
3.5
1 (4)
1 (4)
n2.9 SOUND
EMISSION HOLE
-T-R
SMT-1028
10
0.4 (4)
DESCRIPTION
mA
OHM
dBA
Hz
-20 ~ +70
°C
-40 ~ +85
°C
PA46
Au PLATED COPPER
grams
1
POLARITY (+)
10
REVISION HISTORY
LTR
DUMMY PAD
POLARITY (-)
0.4
2.1
1.5
6.4
NOTES:
1. ALL DIMENSIONS ARE IN MILLIMETERS.
2. SPECIFICATIONS SUBJECT TO CHANGE OR WITHDRAWL
WITHOUT NOTICE.
3. THIS PART IS RoHS 2002/95/EC COMPLIANT.
UNLESS OTHERWISE
SPECIFIED:
DIMENSIONS ARE IN
MILLIMETERS,
TOLERANCES
ARE ±0.5 AND
ANGLES ARE ±3°.
SIZE
A3
SMT-1028-T-R.idw
Designed by
Date
Checked by
Date
Approved by
J.A.F.
8/30/2005
B.R.
8/30/2005
E.P.
Date
Drawn Date
8/30/2005 11/7/2007
SMT-1028-T-R
Transducer (Electro-Mech)
Edition
Sheet
1/1
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
PUI Audio:
SMT-1028-T-R SMT1028TR/REEL SMT-1028-T-2-R
很抱歉,暂时无法提供与“SMT-1028-T-2-R”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+41.149391+5.34044
- 10+31.4287010+4.07888
- 25+28.3585025+3.68042
- 50+26.2848150+3.41129
- 100+24.39446100+3.16596
- 250+22.14712250+2.87430
- 500+20.61559500+2.67553
- 国内价格 香港价格
- 1000+19.213911000+2.49362
- 2000+18.377972000+2.38513
