SMT-1640-S-2-R
SMT-1640-S-2-R
    PUIAUDIO
    AUDIO PIEZO TRANSDUCER 1-25V SMD
SMT-1640-S-2-R 数据手册
SPECIFICATIONS PARAMETERS RATED VOLTAGE OPERATING VOLTAGE RANGE RATED CURRENT (MAX) CAPACITANCE MINIMUM SPL @ 10 CM RESONANT FREQUENCY OPERATING TEMPERATURE STORAGE TEMPERATURE HOUSING MATERIAL TERMINAL MATERIAL WEIGHT VALUES UNIT 5 1 ~ 25 3 16,000 30% 70 4,000 500 -40 ~ +120 -40 ~ +120 LCP Sn PLATED COPPER 1 Vp-p Vp-p 16 REVISION HISTORY LTR DESCRIPTION DATE APPROVED A B RELEASED FROM ENGINEERING REVISED CAPACITANCE SPECIFICATION REVISED SPL 6/8/2011 9/22/2011 3/2/2020 C.W. M.L. M.V. mA pF dBA Hz C C grams 0.2 SMT1640S2R 2 (2) PUI THIS DOCUMENT CONTAINS DATA PROPRIETARY TO PROJECTS UNLIMITED, INC. ANY USE OR REPRODUCTION, IN ANY FORM, WITHOUT PRIOR WRITTEN PERMISSION OF PROJECTS UNLIMITED, INC. IS PROHIBITED. 2003, Projects Unlimited Inc. NOTES: 2.5 2 (2) SOUND PORT 16 0.2 1. ALL DIMENSIONS ARE IN MILLIMETERS. 2. SPECIFICATIONS SUBJECT TO CHANGE OR WITHDRAWL WITHOUT NOTICE. 3. THIS PART IS RoHS 2002/95/EC COMPLIANT. 0.2 0.05 UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN MILLIMETERS, TOLERANCES ARE 0.5 AND ANGLES ARE 3 . SIZE A3 SMT-1640-S-2-R.idw Designed by Date Checked by Date Approved by Date Drawn Date J.D. 6/8/2011 M.L. 6/10/2011 C.W. 6/10/2011 6/8/2011 SMT-1640-S-2-R Transducer (Piezo) Edition Sheet - 1/1
SMT-1640-S-2-R 价格&库存
很抱歉,暂时无法提供与“SMT-1640-S-2-R”相匹配的价格&库存,您可以联系我们找货
SMT-1640-S-2-R
    • 1+15.99566
    • 10+14.41275
    • 100+13.25682
    • 500+12.30916
    • 1000+9.99729
    库存:747
    SMT-1640-S-2-R
    • 800+12.86872800+1.66477
    • 1600+11.993441600+1.55154
    • 2400+11.515912400+1.48976
    • 4000+11.458814000+1.48238
    库存:10146
    SMT-1640-S-2-R
    • 1+23.686051+3.06416
    • 10+18.6019310+2.40645
    • 25+16.9322725+2.19045
    • 50+15.7865150+2.04223
    • 100+14.73029100+1.90559
    • 250+14.02560250+1.81443
    库存:10146
