AT-2310-T-LW100-R
AT-2310-T-LW100-R
    PUIAUDIO
    Peak-Peak Signal Buzzer Single Tone 2kHz Piezo 1 ~ 12V 65dB @ 3V, 10cm
AT-2310-T-LW100-R 数据手册
 AT-2310-T-LW100-R 22.5mm Transducer 3541 Stop Eight Road • Dayton, Ohio 45414 Product Overview                 !   " # $ %&'&("      ) UL7WG w " #k )  Frequency Response (3Vp-p @ 1 cm) PUI Audio Inc. engages in continuous product improvement. All specifications are subject to change without notice. www.puiaudio.com. Copyright © 2015. Last Revised 9/15.  AT-1438-TWT-R AT-2310-T-LW100-R 40mm Speaker 22.5mm Transducer Mechanical and Environment Testing Packaging Test Description Test Condition High Temperature 95°C (±2°C) with random humidity for 240 hours Low Temperature -40°C (±2°C) with random humidity for 240 hours 40°C (±2°C) with 95% relative humidity for 240 hours 1.5 mm movement modulated at 10-55 Hz in 3 directions for 2 hours 75 cm free fall onto wood board, 10 cycles Humidity Vibration Drop Test After tests, part shall rest for 2 hours. SPL shall not deviate more than ±3.5 dB. Frequency Response and SPL Measurement Setup  PUI Audio Inc. engages in continuous product improvement. All specifications are subject to change without notice. www.puiaudio.com. Copyright © 2015. Last Revised 9/15. SPECIFICATIONS PARAMETERS RATED VOLTAGE OPERATING VOLTAGE RANGE RATED CURRENT (MAX) CAPACITANCE MINIMUM SPL @ 1 CM RESONANT FREQUENCY OPERATING TEMPERATURE STORAGE TEMPERATURE HOUSING MATERIAL TERMINAL MATERIAL WEIGHT VALUES UNITS 3 1 ~ 12 3 90,000 “ 30% 108“3 2,000 “ 500 -30 ~ +85 -40 ~ +95 ABS LEAD WIRE 1.1 Vp-p Vp-p THIS DOCUMENT CONTAINS DATA PROPRIETARY TO PROJECTS UNLIMITED, INC. ANY USE OR REPRODUCTION, IN ANY FORM, WITHOUT PRIOR WRITTEN PERMISSION OF PROJECTS UNLIMITED, INC. IS PROHIBITED. REVISION HISTORY LTR DESCRIPTION DATE APPROVED A B C D RELEASED FROM ENGINEERING REVISED RESONANT FREQUENCY REVISED RATED VOLTAGE AND SPL REVISED TO INVENTOR 3-D DRAWING TEMPLATE REVISED SPL DISTANCE 10/25/2006 6/16/2008 1/5/2010 6/8/2010 5/27/2010 B.R. B.R. B.R. B.R. ‹2003, Projects Unlimited Inc. mA pF dBA Hz ƒC ƒC grams 3.2 P22.5 100 B5 BLACK (-) 5 B2 UL1571 AWG #32 RED (+) NOTES: 1. ALL DIMENSIONS ARE IN MILLIMETERS. 2. SPECIFICATIONS SUBJECT TO CHANGE OR WITHDRAWL WITHOUT NOTICE. 3. THIS PART IS RoHS 2002/95/EC COMPLIANT. UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN MILLIMETERS, TOLERANCES ARE “0.5 AND ANGLES ARE “3ƒ. SIZE A3 AT-2310-T-LW100-R.idw Designed by Date Checked by Date Approved by J.D. 10/26/2006 R.W. 10/25/2006 B.R. Date Drawn Date 10/26/2006 6/8/2010 AT-2310-T-LW100-R Transducer (Piezo) Edition Sheet - 1/1
AT-2310-T-LW100-R 价格&库存
很抱歉,暂时无法提供与“AT-2310-T-LW100-R”相匹配的价格&库存,您可以联系我们找货
