Additional Resources:
Product Page
3D Model
PCB Footprint
date
08/05/2022
page 1 of 3
MODEL: CX-1606C | DESCRIPTION: MAGNETIC BUZZER INDICATOR
FEATURES
• magnetic indicator with pin mount
• 6 Vdc rating
• 2,200 Hz rated frequency
SPECIFICATIONS
parameter
conditions/description
min
rated voltage
typ
max
6.0
operating voltage
current consumption
4.0
at rated voltage
rated frequency
sound pressure level
at 10 cm (A-weight), rated voltage
dimensions
Ø16.0 x 14.0
1,900
2,200
85
92
Vdc
7.0
Vdc
50
mA
2,500
4.6
PPO
terminal
pin type (Au plating)
Hz
dBA
mm
weight
material
units
g
operating temperature
-20
60
°C
storage temperature
-30
70
°C
max
units
380
°C
washable
yes
RoHS
Notes:
yes
1. All specifications measured at 5~35°C, humidity at 45~85%, under 86~106kPa pressure, unless otherwise noted.
SOLDERABILITY
parameter
hand soldering
2
Notes:
min
for maximum 2 seconds
330
2. Not recommended for wave soldering
cuidevices.com
typ
Product Page
3D Model
PCB Footprint
CUI DEVICES | MODEL: CX-1606C | DESCRIPTION: MAGNETIC BUZZER INDICATOR
date 08/05/2022 | page 2 of 3
MECHANICAL DRAWING
units: mm
tolerance: ±0.5 mm
PERFORMANCE CURVES
Voltage vs. Current Consumption
at 25°C
Current Consumption (mA)
Sound Pressure Level (dB)
Voltage vs. Sound Pressure Level
at 10 cm, 25°C
100
95
90
85
4
4.5
5
5.5
6
Voltage (Vdc)
6.5
35
30
25
7
cuidevices.com
4.5
5
5.5
6
Voltage (Vdc)
6.5
7
Product Page
3D Model
PCB Footprint
date 08/05/2022 | page 3 of 3
REVISION HISTORY
rev.
description
date
1.0
initial release
01/30/2006
1.01
brand update
01/14/2020
logo, datasheet style update
08/05/2022
1.02
The revision history provided is for informational purposes only and is believed to be accurate.
CUI Devices offers a one (1) year limited warranty. Complete warranty information is listed on our website.
CUI Devices reserves the right to make changes to the product at any time without notice. Information provided by CUI Devices is believed to be accurate
and reliable. However, no responsibility is assumed by CUI Devices for its use, nor for any infringements of patents or other rights of third parties which may
result from its use.
CUI Devices products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A
critical component is any component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life
support device or system, or to affect its safety or effectiveness.
cuidevices.com
很抱歉,暂时无法提供与“CX-1606C”相匹配的价格&库存,您可以联系我们找货
