AI-1441-TWT-12V-R
AI-1441-TWT-12V-R
    PUIAUDIO
    DC Buzzer Single Tone 4.1kHz Piezo 3 ~ 16V 80dB @ 12V, 10cm
AI-1441-TWT-12V-R 数据手册
SPECIFICATIONS PARAMETERS RATED VOLTAGE OPERATING VOLTAGE RANGE RATED CURRENT (MAX) MINIMUM SPL @ 10 CM RESONANT FREQUENCY TONE OR PULSE RATE OPERATING TEMPERATURE STORAGE TEMPERATURE HOUSING MATERIAL TERMINAL MATERIAL WEIGHT VALUES UNITS 12 3 ~ 16 Vdc Vdc 7 80 4,100 500 CONTINUOUS -20 ~ +70 -30 ~ +80 PPO Au PLATED BRASS 1 mA dBA Hz 0 pulse/sec THIS DOCUMENT CONTAINS DATA PROPRIETARY TO PROJECTS UNLIMITED, INC. ANY USE OR REPRODUCTION, IN ANY FORM, WITHOUT PRIOR WRITTEN PERMISSION OF PROJECTS UNLIMITED, INC. IS PROHIBITED. 2003, Projects Unlimited Inc. REVISION HISTORY LTR DESCRIPTION DATE - RELEASED FROM ENGINEERING 2014/06/25 APPROVED C C grams 7.6 5.5 POTTING 13.7 WASH TAB 7.62 SOUND HOLE 0.7 4.5 0.1 (2) NOTES: 1. ALL DIMENSIONS ARE IN MILLIMETERS. 2. SPECIFICATIONS SUBJECT TO CHANGE OR WITHDRAWL WITHOUT NOTICE. 3. THIS PART IS RoHS 2011/65/EU COMPLIANT. UNLESS OTHERWISE SPECIFIED: All PURCHASES ARE SUBJECT TO AND INCORPORATE THE PUI AUDIO TERMS AND CONDITIONS SALE FOUND AT http://www.puiaudio.com /pdf/terms_conditions.pdf (paper copy available upon request). DIMENSIONS ARE IN MILLIMETERS, TOLERANCES ARE 0.5 AND ANGLES ARE 3 . SIZE A3 AI-1441-TWT-12V-R.idw Designed by Date Checked by Date Approved by J.D. 6/25/2014 C.W. 6/25/2014 R.W. Date Drawn Date 6/25/2014 6/25/2014 AI-1441-TWT-12V-R Indicator Edition Sheet - 1/1
AI-1441-TWT-12V-R 价格&库存
很抱歉,暂时无法提供与“AI-1441-TWT-12V-R”相匹配的价格&库存,您可以联系我们找货
