CC-0601
CC-0601
    CUIDEVICES
    BUZZER MAGNET 1.5V 6.6MM RADIAL
CC-0601 数据手册
Additional Resources: Product Page | 3D Model | PCB Footprint date 08/05/2022 page 1 of 3 MODEL: CC-0601 | DESCRIPTION: MAGNETIC BUZZER TRANSDUCER FEATURES • through hole • 1.5 V rated • externally driven SPECIFICATIONS parameter rated voltage conditions/description Vo-p operating voltage current consumption min 1.0 at rated voltage, 3,000 Hz square wave, ½ duty at 10 cm (A-weight), rated voltage, 3,000 Hz square wave, ½ duty coil resistance dimensions max 1.5 0V rated frequency sound pressure level typ Vo-p 1.7 Vo-p 80 mA 3,000 Hz 70 77 dBA 5 6 7 Ø6.6 x 3.5 0.4 PPO terminal pin type (Au plating) Ω mm weight material units g operating temperature -20 60 °C storage temperature -30 70 °C max units 380 °C RoHS Notes: yes 1. All specifications measured at 5~35°C, humidity at 45~85%, under 86~106 kPa pressure, unless otherwise noted. SOLDERABILITY parameter conditions/description min hand soldering2 for maximum 2 seconds 330 Notes: 2. Not recommended for wave soldering cuidevices.com typ Additional Resources: Product Page | 3D Model CUI DEVICES | MODEL: CC-0601 | DESCRIPTION: MAGNETIC BUZZER TRANSDUCER MECHANICAL DRAWING units: mm tolerance: ±0.5 mm 01 06 Week 01 02 Year 19---2019 20---2020 FREQUENCY RESPONSE CURVE APPLICATION CIRCUIT cuidevices.com | PCB Footprint date 08/05/2022 | page 2 of 3 Additional Resources: Product Page | 3D Model | PCB Footprint CUI DEVICES | MODEL: CC-0601 | DESCRIPTION: MAGNETIC BUZZER TRANSDUCER date 08/05/2022 | page 3 of 3 REVISION HISTORY rev. description date 1.0 initial release 08/21/2006 1.01 brand update 02/04/2020 logo, datasheet style update 08/05/2022 1.02 The revision history provided is for informational purposes only and is believed to be accurate. CUI Devices offers a one (1) year limited warranty. Complete warranty information is listed on our website. CUI Devices reserves the right to make changes to the product at any time without notice. Information provided by CUI Devices is believed to be accurate and reliable. However, no responsibility is assumed by CUI Devices for its use, nor for any infringements of patents or other rights of third parties which may result from its use. CUI Devices products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A critical component is any component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life support device or system, or to affect its safety or effectiveness. cuidevices.com
CC-0601 价格&库存
很抱歉,暂时无法提供与“CC-0601”相匹配的价格&库存,您可以联系我们找货
