This document contains data proprietary to PUI Audio Inc. Any use or reproduction, in any form, without prior written permission
of PUI Audio Inc. is prohibited.
©2021, PUI Audio Inc.
Data Sheet
Insert PUI Audio Part Number
Features:
• Wide 6 to 16 VDC operating voltage range
• Includes removable wash tab
• Small 12mm diameter with high 85 dB @ 10cm output
Specifications
Parameters
Rated Voltage
Operating Voltage Range
Current Draw at Rated Voltage
Minimum SPL @ 10cm
Resonant Frequency
Tone or Pulse Rate
Housing Material
Terminal Material
Weight
Values
12
6 ~ 16
30
85
2,300 ±300
Continuous Tone
PBT
Gold-plated Brass
2
Acceptable Soldering Methods
Environmental Compliances
Storage Temperature
Operating Temperature
Hand Solder, Wave Solder
RoHS/REACH
-30 ~ +80
-20 ~ +70
Measurement Method
PUI Audio, Inc., 3541 Stop Eight Road, Dayton, OH 45414
Tel: (937) 415-5901 Fax: (937) 415-5925
Units
VDC
VDC
mA
dBA
Hz
Grams
See page 2 for soldering
information
°C
°C
Typical SPL and Current Draw vs Input Voltage
Recommended Wave Soldering Procedure
Reliability Testing
Type of Test
High Temperature Test
Low Temperature Test
Humidity Test
Test Specifications
96 hours at 80°C
96 hours at -30°C
96 hours at 40°C with relative humidity at 98%
The part is subjected to 10 cycles of the following
test cycle:
Temperature Cycle Testing
The part is subjected to a vibration amplitude of
1.5mm with 10 to 55 Hz vibration frequency to
Vibration Test
each of the 3 axes (X, Y, Z) for 2 hours each.
The part is dropped from a height of 75 cm onto a
40mm thick wood board 3 times in each of the 3
Drop Test
axes (X, Y, Z) for a total of 9 drops.
After each test, the part shall meet specifications without any damage to appearance or
performance. SPL shall be ±10 dB when compared to the initial measurement.
Dimensions (4.5mm long pin is positive, polarity is also indicated on the wash tab)
Revision
A
Note:
1.
2.
3.
Specifications Revisions
Description
Released from Engineering
Revised Operating Voltage Range
Unless otherwise specified:
A. All dimensions are in millimeters.
B. Default tolerances are ±0.5mm and angles are ±3°.
Specifications subject to change or withdrawal without notice.
This part is ROHS 2015/863/EU compliant. (Exemption 7c-1 for piezo type).
Date
6/25/2014
3/16/2021
AI-1223-TWT-12V-3-R 价格&库存
很抱歉,暂时无法提供与“AI-1223-TWT-12V-3-R”相匹配的价格&库存,您可以联系我们找货
