THIS DOCUMENT CONTAINS DATA PROPRIETARY TO
PROJECTS UNLIMITED, INC. ANY USE OR
REPRODUCTION, IN ANY FORM, WITHOUT PRIOR
WRITTEN PERMISSION OF PROJECTS UNLIMITED,
INC. IS PROHIBITED.
2003, Projects Unlimited Inc.
SPECIFICATIONS
PARAMETERS
RATED VOLTAGE
OPERATING VOLTAGE RANGE
RATED CURRENT (MAX)
COIL RESISTANCE
MINIMUM SPL @ 10 CM
RESONANT FREQUENCY
OPERATING TEMPERATURE
STORAGE TEMPERATURE
HOUSING MATERIAL
TERMINAL MATERIAL
WEIGHT
VALUES
UNIT
3.6
2.5 ~ 4.5
90
15 3
85
2,500 500
-30 ~ +70
-40 ~ +85
LCP
Sn PLATED
PHOSPHOR BRONZE
0.4
V0-p
V0-p
mA
OHM
dBA
Hz
C
C
REVISION HISTORY
LTR
DESCRIPTION
DATE
APPROVED
A
B
C
D
RELEASED FROM ENGINEERING
ADDED RoHS COMPLIANCE NOTE
REVISED TO INVENTOR 3-D DRAWING TEMPLATE
ADDED REFLOW NOTE
REVISED VOLTAGE UNITS, PAD MAX DEFLECTION
4/1/2005
8/10/2005
4/30/2010
1/25/2019
2/28/2020
B.R.
M.L.
M.V.
A(5:1)
B
grams
1.5
3
8.5
8.5
POLARITY
PAD (-)
0.7
DUMMY
PAD
07.C
T0825S4R
PUI
KOREA
POLARITY
PAD (+)
0.1 (3)
0.7
0.3
0.1
SOUND
EMISSION
HOLE
3
DUMMY
PAD
PAD
0.05 MAX
DETAIL "B"
NOTES:
1. ALL DIMENSIONS ARE IN MILLIMETERS.
2. SPECIFICATIONS SUBJECT TO CHANGE OR WITHDRAWL
WITHOUT NOTICE.
3. THIS PART IS RoHS 2011/65/EU COMPLIANT.
4. REFLOW ACCEPTABLE. MAX TEMP 260C, 10sec OR LESS.
BOTTOM OF
TRANSDUCER
0.5 MAX
UNLESS OTHERWISE
SPECIFIED:
DIMENSIONS ARE IN
MILLIMETERS,
TOLERANCES
ARE 0.5 AND
ANGLES ARE 3 .
SIZE
A3
SMT-0825-S-4-R.idw
Designed by
Date
Checked by
Date
Approved by
Date
Drawn Date
G.V.
4/1/2005
E.P.
4/1/2005
R.W.
4/1/2005
4/30/2010
SMT-0825-S-4-R
Transducer (Electro-Mech)
Edition
Sheet
1/1
很抱歉,暂时无法提供与“SMT-0825-S-4-R”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1000+16.839041000+2.10618
- 国内价格 香港价格
- 1+33.402331+4.17787
- 10+26.2533410+3.28369
- 25+23.9115625+2.99079
- 50+22.3043450+2.78977
- 100+20.82047100+2.60417
- 250+20.61111250+2.57798
