SMT-0825-T-2-R
SMT-0825-T-2-R
    PUIAUDIO
    AUDIO MAGNETIC XDCR 2.5-4.5V SMD
SMT-0825-T-2-R 数据手册
SPECIFICATIONS PARAMETERS RATED VOLTAGE OPERATING VOLTAGE RANGE RATED CURRENT (MAX) COIL RESISTANCE MINIMUM SPL @ 10 CM RESONANT FREQUENCY OPERATING TEMPERATURE STORAGE TEMPERATURE HOUSING MATERIAL TERMINAL MATERIAL WEIGHT VALUES UNIT 3.6 2.5 ~ 4.5 90 15 3 85 2,700 500 -30 ~ +70 -40 ~ +85 LCP Sn PLATED PBS 0.40 V0-p V0-p THIS DOCUMENT CONTAINS DATA PROPRIETARY TO PROJECTS UNLIMITED, INC. ANY USE OR REPRODUCTION, IN ANY FORM, WITHOUT PRIOR WRITTEN PERMISSION OF PROJECTS UNLIMITED, INC. IS PROHIBITED. 2003, Projects Unlimited Inc. mA OHM dBA Hz C C grams REVISION HISTORY LTR DESCRIPTION DATE APPROVED A B RELEASED FROM ENGINEERING REVISED TO INVENTOR 3-D DRAWING TEMPLATE REVISED VOLTAGE UNITS AND TERMINAL MATERIAL 5/17/2006 5/3/2010 2/28/2020 B.R. M.V. A(5:1) B 1.5 POLARITY PAD (+) 0.2 DUMMY PAD 0.2 KOREA 06 C T0825TR PUI 8.5 8.5 POLARITY PAD (-) 0.2 0.3 0.1 DUMMY PAD 1.8 SOUND EMISSION HOLE NOTES: 1. ALL DIMENSIONS ARE IN MILLIMETERS. 2. SPECIFICATIONS SUBJECT TO CHANGE OR WITHDRAWL WITHOUT NOTICE. 3. THIS PART IS RoHS 2002/95/EC COMPLIANT. 3 0.1 (3) PAD DETAIL "B" BOTTOM OF TRANSDUCER UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN MILLIMETERS, TOLERANCES ARE 0.5 AND ANGLES ARE 3 . 0.05 MAX. 0.05 MAX. SIZE A3 SMT-0825-T-2-R.idw Designed by Date Checked by Date Approved by Date Drawn Date J.D. 5/17/2006 E.P. 5/17/2006 B.R. 5/17/2006 5/3/2010 SMT-0825-T-2-R Transducer (Electro-Mech) Edition Sheet - 1/1
SMT-0825-T-2-R 价格&库存
很抱歉,暂时无法提供与“SMT-0825-T-2-R”相匹配的价格&库存,您可以联系我们找货
SMT-0825-T-2-R
  • 1000+20.443961000+2.64497
  • 2000+19.693092000+2.54783
库存:586
SMT-0825-T-2-R
    • 1+40.14360
    • 200+16.01640
    • 500+15.48720
    • 1000+15.21720
    SMT-0825-T-2-R
    • 1+38.381041+4.96562
    • 10+30.2010510+3.90732
    • 25+27.5216425+3.56066
    • 50+25.6749550+3.32174
    • 100+24.10438100+3.11855
    库存:586
