Additional Resources:
Product Page
3D Model
date
08/05/2022
page 1 of 4
MODEL: CPE-420 | DESCRIPTION: PIEZO BUZZER INDICATOR
FEATURES
• wire lead with panel-mount tabs
• 12 Vdc rating
• 102 dB
• 2.8 kHz rated frequency
SPECIFICATIONS
parameter
conditions/description
min
rated voltage
max
12
operating voltage
current consumption
typ
3
at rated voltage
rated frequency
2,300
sound pressure level
at 30 cm, rated voltage
dimensions
Ø41.8 x 22.0
ABS UL94 1/16” HB (black)
terminal
wire leads
Vdc
16
Vdc
50
mA
3,300
102
Hz
dB
mm
weight
material
2,800
units
17.4
g
operating temperature
-30
85
°C
storage temperature
-40
95
°C
RoHS
Notes:
yes
1. All specifications measured at 5~35°C, humidity at 45~85%, under 86~106kPa pressure, unless otherwise noted.
cuidevices.com
Product Page
3D Model
CUI DEVICES | MODEL: CPE-420 | DESCRIPTION: PIEZO BUZZER INDICATOR
date 08/05/2022 | page 2 of 4
MECHANICAL DRAWING
units: mm
tolerance: ±0.5 mm
3.4
(2 PLCS)
7.0
UL1007 LF 24AWG
5.0
59.5
2.0
black
red
140.0
50.0
41.8
10.0
22.0
PERFORMANCE CURVES
P: Voltage vs. Sound Pressure Level
I: Voltage vs. Current Consumption
cuidevices.com
Product Page
PACKAGING
units: mm
Outer Box Size: 310 x 248 x 49 mm
Carton Size: 550 x 330 x 290 mm
Outer Box QTY: 70 pcs per box
Carton QTY: 700 pcs per carton
cuidevices.com
3D Model
date 08/05/2022 | page 3 of 4
Product Page
3D Model
date 08/05/2022 | page 4 of 4
REVISION HISTORY
rev.
description
date
1.0
initial release
11/12/2007
1.01
applied new spec template
06/17/2015
1.02
changed internal piezo element
01/11/2018
1.03
brand update
11/15/2019
1.04
logo, datasheet style update
08/05/2022
The revision history provided is for informational purposes only and is believed to be accurate.
CUI Devices offers a one (1) year limited warranty. Complete warranty information is listed on our website.
CUI Devices reserves the right to make changes to the product at any time without notice. Information provided by CUI Devices is believed to be accurate
and reliable. However, no responsibility is assumed by CUI Devices for its use, nor for any infringements of patents or other rights of third parties which may
result from its use.
CUI Devices products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A
critical component is any component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life
support device or system, or to affect its safety or effectiveness.
cuidevices.com
很抱歉,暂时无法提供与“CPE-420”相匹配的价格&库存,您可以联系我们找货
