SPECIFICATIONS
PARAMETERS
RATED VOLTAGE
OPERATING VOLTAGE RANGE
RATED CURRENT (MAX)
MINIMUM SPL @ 10 CM
RESONANT FREQUENCY
TONE OR PULSE RATE
OPERATING TEMPERATURE
STORAGE TEMPERATURE
HOUSING MATERIAL
TERMINAL MATERIAL
WEIGHT
VALUES
UNITS
12
3 ~ 28
18
87
1,800 500
CONTINUOUS
-30 ~ +80
-40 ~ +80
ABS
Sn PLATED
PHOSPHER
BRONZE
5.8
Vdc
Vdc
mA
dBA
Hz
0 pulse/sec
THIS DOCUMENT CONTAINS DATA PROPRIETARY TO
PROJECTS UNLIMITED, INC. ANY USE OR
REPRODUCTION, IN ANY FORM, WITHOUT PRIOR
WRITTEN PERMISSION OF PROJECTS UNLIMITED,
INC. IS PROHIBITED.
2003, Projects Unlimited Inc.
LTR
A
B
C
D
E
DATE
9/23/2005
5/6/2009
11/9/2009
2/8/2010
9/7/2016
2/24/2020
APPROVED
B.R.
B.R.
B.R.
B.R.
M.V.
C
C
grams
5.5
DATE CODE
WWYY
17.5
3.85 0.1 SOUND
EMISSION HOLE
XXXX
30
REVISION HISTORY
DESCRIPTION
RELEASED FROM ENGINEERING
REVISED MAX. CURRENT
ADDED NOTE NUMBER 4
REVISED TO INVENTOR 3-D DRAWING TEMPLATE
ADDED DATE CODE
REVISED WEIGHT
0.8
15
0.1 (2)
NOTES:
1. ALL DIMENSIONS ARE IN MILLIMETERS.
2. SPECIFICATIONS SUBJECT TO CHANGE OR WITHDRAWL
WITHOUT NOTICE.
UNLESS OTHERWISE
SPECIFIED:
3. THIS PART IS RoHS 2011/65/EU COMPLIANT.
DIMENSIONS ARE IN
MILLIMETERS,
4. HAND SOLDER ONLY; IRON TEMP 350c AND SOLDER TIME 3 SECONDS OR LESS. WAVE
SOLDERING NOT ALLOWED. MINIMUM INSULATION RESISTANCE BETWEEN FEEDBACK
CIRCUIT AND GROUND IS 20M OHMS.
TOLERANCES
ARE 0.5 AND
ANGLES ARE 3 .
SIZE
A3
AI-3018-TWT-R.idw
Designed by
Date
Checked by
Date
Approved by
Date
Drawn Date
J.A.F.
9/23/2005
E.P.
9/23/2005
B.R.
9/23/2005
2/8/2010
AI-3018-TWT-R
Indicator
Edition
Sheet
1/1
很抱歉,暂时无法提供与“AI-3018-TWT-R”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+47.453311+6.13936
